ok so my oil drain bolt is stuck...help
Old Jan 12, 2005 | 06:41 PM
GroundZer0 336's Avatar
Default ok so my oil drain bolt is stuck...help
well i thought it was just stuck, like over torqued or somethin, so i eventually got it to break loose, but now it just spins and doesnt come out any??wtf. im screwed i need to change my oil pretty bad and im about to drive 4 hours friday.
i really wanted to change my oil before that. tomororw im gona try to pry it out some while i loosen it to see if that helps.
Old Jan 12, 2005 | 06:44 PM
onePOINTsix's Avatar
Default Re: ok so my oil drain bolt is stuck...help (GroundZer0 336)
new pan or drill the old threds out and helicoil it if possible, i'd just reccomend a new pan tho
Old Jan 12, 2005 | 07:06 PM
slowpokesi's Avatar
time for a new pan, before you pull it down be sure to get a new oil gasket, you in for one big ******* mess!
Old Jan 12, 2005 | 08:11 PM
vegaskurt's Avatar
Default Re: ok so my oil drain bolt is stuck...help (slowpokesi)
It just spins??? woooh. Dont drill it out, dont risk putting shavings in your oil pan. Just get a new pan and gasket.
Old Jan 12, 2005 | 08:13 PM
RCautoworks's Avatar
Default Re: ok so my oil drain bolt is stuck...help (vegaskurt)
Have you made sure you can't get it out anyway ? Try applying downward pressure on it while spinning it. If that don't work just buy a new used pan, you could find them for cheap if you look around.
Old Jan 12, 2005 | 08:20 PM
naptownrex's Avatar
same thing happend to me- its prolly all stripped from what u say- i got mine out by pulling with a clamp kinda wrench while using another wrench to loosen it... I was able to pull the bolt out enough for it to grab on to the non stripped part and eventually come out (if that makes any sense). then i got one of those fram quick drain oil nuts and used i think some sort of like leak stopper stuff- it came in a tube and was similar to caulk.. anyway i put that around the bolt and smothered it, and stuck it up in there. The stuff i bought was suppost to dry hard or something, and it did ok. granted it did leak a lil, but i fixed it for like 15 bucks instead of like 85-90 or what ever oil pans run these days. My other choice if that didnt work was to epoxy that bitch in there- I found some stuff that would be like cement, which is fine since u never have to take the drain nut out again if u get the fram quick drain system. anyways, thats just what i did- certainly not the "right way" of doing it, but if ur short on cash, its a some what plausible option.
Old Jan 13, 2005 | 09:14 AM
Default Re: ok so my oil drain bolt is stuck...help (naptownrex)
i think im just gona get a new pan, i have to tap one for my turbo oil line anyways. hopefully theres some on ebay or somebody on here has one.
PhilMac
11
Sep 14, 2007 06:23 AM
projectej8
11
Apr 3, 2005 02:45 PM
stareatsun
Nov 18, 2004 08:23 PM
MR. ARIZONA
Sep 3, 2003 05:04 PM
fluke702
Feb 20, 2002 06:46 AM
