replacing two rods...what about the bearings?
Old Jan 12, 2005 | 05:43 PM
hOndafienD 04's Avatar
Default replacing two rods...what about the bearings?
on a 95 jdm h22a......im replacing 2 rods because they are bent...should i get new rod bearings or use the old ones?
Old Jan 12, 2005 | 07:05 PM
v4lu3s's Avatar
RTFM
to mo common sense would dictate that you repalce wear parts like bearings, but then again common sense is not all that common on honda-tech.
Old Jan 12, 2005 | 07:33 PM
crdcz03's Avatar
Fortune Cookie Member
Default Re: (v4lu3s)
replace them
MyVtec8yourV8's Avatar
ill answer your question since otheres want to just talk ****...
YES replace the bearings.. and if the motor has a lot of mines on it replace all the bearings and seals while you have the motor appart... also if youtake the piston out of the cylinder you have to get new rings.. the old ones wont seat right...
Old Jan 12, 2005 | 08:01 PM
common sense says duhh....but the thing is that this is not a motor for me, and my friend that i am replacing the rods for, just wanted to see more opinions other then my own.....trust me if this was my engine i'd replace all the rings, all the bearings, all the seals, all the gaskets, water pump, timing belt etc, since everything is apart now its a lot to just do everything now, but like i said....this isnt for me..
Old Jan 12, 2005 | 08:07 PM
crdcz03's Avatar
Default Re: (hOndafienD 04)
tell your friend not to be a cheapass.
tell him he is building an engine not a lego police station
Old Jan 12, 2005 | 08:09 PM
lol....he works at dounkin donuts....i dont blame him for being cheap...but your right.
Old Jan 13, 2005 | 03:10 PM
LudeyKrus's Avatar
Default Re: (SHORT-DOG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHORT-DOG &raquo;</TD></TR><TR><TD CLASS="quote">youre such a dumb ***!!!!! and you say youre not a rookie on this!!please!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHORT-DOG &raquo;</TD></TR><TR><TD CLASS="quote">keep ******* with me i had already stop but you wanted to keep going right so **** you now.... youre just a dumb ***..</TD></TR></TABLE>
Quit playin w/ your short little weiner dog and get the **** outta here.
Back on topic: replace them, they're fairly cheap and it's is better to replace them now than to replace them on down the road.
Old Jan 13, 2005 | 03:41 PM
thats what i told him, and since im doing the work...i dont have to rip all that **** out again because i didnt do something that i coulda done...
Old Jan 13, 2005 | 05:12 PM
funkmasterchipz's Avatar
yes u MUST replace them, what happens is the bearings will wear with the rod journal and could damage the new rod thats bad by the way just get allll new bearings and rings and gaskets it will be better off
Old Jan 13, 2005 | 05:28 PM
satan_srv's Avatar
Default Re: (funkmasterchipz)
he would be a major retard not to replace them...too cheap to spend money on a few bearings...till he spins one on his brand new rods and has to rebuild his ******* motor...
your question has been answered.
nemesis25
Aug 2, 2012 11:30 AM
H22isnotabigblock
Dec 27, 2006 12:25 PM
Revi
Sep 26, 2006 06:16 AM
ThirdGenLSR209
Jan 23, 2004 02:53 PM
jdmhatch94
May 19, 2002 12:27 PM
