HELP ME on OEM FOGS!
Old Jan 12, 2005 | 05:15 PM
marc-111's Avatar
Default HELP ME on OEM DEPO FOGS!
what i want is when i turn on my city lights (not the headlight yet) i want my foglights to turn on with it? wired fog lights to come on with city light?
how do you rewire that one?
BTW i got an OEM DEPOone which i just installed it. IT lights up when i press the switch, but i want it to light only when i turn on my city lights too!
like this one but i have the stock headlights USDM>>>> http://www.cardomain.com/id/silvferio
thanks!
__________________
Modified by marc-111 at 6:27 PM 1/12/2005
Old Jan 12, 2005 | 05:18 PM
jlacoy82's Avatar
71.192.16.183
Default Re: HELP ME on OEM FOGS! (marc-111)
Instead of running the power wire for the fogs off the battery, use a relay to power the lights, and have the relay activated by the city lights power wire.
Old Jan 12, 2005 | 05:22 PM
marc-111's Avatar
Default Re: HELP ME on OEM FOGS! (jlacoy82)
how do you do that? i'm not good on wiring stuff? do you have like a step by step?
BTW i think i got a relay already with this one (DEPO OEM foglights)
Old Jan 12, 2005 | 05:25 PM
cxSHOE's Avatar
hummm i have the jdm harness and it works with the city lights, can you take photos and post them i wondering if the harness is different from the jdm one. i'll see if i can help in some way.
Old Jan 12, 2005 | 05:26 PM
cxSHOE's Avatar
ahh nevermind you said you have the depos... those are not oem. as your title states...
Old Jan 12, 2005 | 05:28 PM
jlacoy82's Avatar
71.192.16.183
Learn how to wire up a relay, but basically this is all you do:
Power in on relay: from battery
Ground: Ground
Power to activate relay: from city lights + wire
Power out of relay: to fog lights
Bah, I'm too lazy to explain it. Do it with a relay, dont just tap into the city lights harness whatever you do, unless you want melted wires/fire hazard.
Old Jan 12, 2005 | 05:33 PM
99hatch's Avatar
Default Re: (jlacoy82)
just installed me OEM fogs on my EK yesterday and they are awesome!
Old Jan 12, 2005 | 05:36 PM
Nate047's Avatar
Default Re: (99hatch)
You can do an easy wire swap to make the fogs be able to be on with parking lights as well as the high beams. I'm assuming your city lights are wired to your parking lights, so this is probably the easiest way for you to do it... I can find the link if you want to try that way...
Old Jan 12, 2005 | 05:41 PM
marc-111's Avatar
Default Re: (Nate047)
ok i'll try that way instead of the relay stuff, that's hard and i might short some wires on their
Old Jan 12, 2005 | 05:54 PM
marc-111's Avatar
Default Re: (marc-111)
coud you post a link? on how to do that?
Old Jan 12, 2005 | 10:52 PM
Go_Fork_Urself's Avatar
Ey marc i didnt expect to find you here lolz
Old Jan 13, 2005 | 02:38 AM
marc-111's Avatar
Default Re: (Go_Fork_Urself)
just fixed my account here
give me a step by step on how to wire stuff without relaying anything
Old Jan 13, 2005 | 03:00 AM
White95SiHB's Avatar
Default Re: HELP ME on OEM DEPO FOGS! (marc-111)
Refer to the above pic. My Depo set had the exact same wires. Look at the wires on the left. The red wire with the circle end goes directly to the battery. On that red wire is the fuse holder, then the plug with the relay. After the relay plug, are the foglight wires that plug into the foglights themselves. There is also a ground wire. Find a bolt somewhere on the frame behind the bumper to ground the ground wire. Now look to the red wiring on the far right of that pic. That attaches to the end of the foglight wiring, then goes through the firewall and connects to the wiring in the middle of the pic, which is the switch wiring harness. The switch harness connects to the red wire and the switch. There is also a groundwire that needs to be grounded. There are a few bolts under the dash that you can attach the groundwire to. If my instructions are hard to comprehend, then forgive me as it is 4am and I'm bout to go to sleep.
Old Jan 13, 2005 | 09:20 AM
marc-111's Avatar
Default Re: HELP ME on OEM DEPO FOGS! (White95SiHB)
yah i already did that, what i want now is when i turn on my parklights/ city lights i also want my fog to turn on
Old Jan 13, 2005 | 09:54 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 &raquo;</TD></TR><TR><TD CLASS="quote">yah i already did that, what i want now is when i turn on my parklights/ city lights i also want my fog to turn on</TD></TR></TABLE>
there's a plug that goes into your under dash fuse box. plug it into the one that's fourth from the left. that's how mine are hooked up and they turn on with my parking lights, headlights, and high beams.
Old Jan 13, 2005 | 10:08 AM
Strange, that's how mine are wired up and they turn on with the parking lights.
Old Jan 13, 2005 | 10:22 AM
marc-111's Avatar
yah i already did that, still it does not work?
don't i need to rewire something on the swith near the steering wheel? where you turn on the parklights?
Old Jan 13, 2005 | 10:24 AM
RC_Lyle's Avatar
post
Old Jan 13, 2005 | 02:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 &raquo;</TD></TR><TR><TD CLASS="quote">yah i already did that, still it does not work?
don't i need to rewire something on the swith near the steering wheel? where you turn on the parklights?</TD></TR></TABLE>
Did you plug the switch harness into the #2 slot?
Old Jan 13, 2005 | 02:25 PM
USDMGD3!'s Avatar
i plugged mine into slot #4 and it turns on with my parking lights.
Old Jan 13, 2005 | 03:08 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White95SiHB &raquo;</TD></TR><TR><TD CLASS="quote">Did you plug the switch harness into the #2 slot?
i think this pic is upside down. if it is, then it's plugged into the right slot
Old Jan 13, 2005 | 03:59 PM
Default Re: HELP ME on OEM DEPO FOGS! (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
i think this pic is upside down. if it is, then it's plugged into the right slot </TD></TR></TABLE>
Haha yeah I was upside down when I took that pic...my butt was on the driver's seat and my head was under the dash.
Old Jan 14, 2005 | 01:56 AM
marc-111's Avatar
yup i plug it right their
Old Jan 14, 2005 | 03:30 AM
6SPD_EK's Avatar
https://honda-tech.com/zerothread?id=707193 &lt;--- complete instructions
<FONT SIZE="5"> ^ thats for 96-00 civics </FONT>
Modified by adirondackR at 1:14 PM 1/14/2005
Old Jan 14, 2005 | 07:05 AM
USDMGD3!'s Avatar
Default Re: HELP ME on OEM DEPO FOGS! (adirondackR)
i plugged mine into all the open slots avalible and my fogs didnt wanna turn on. like i said i put it in slot #4 and it works with my parking lights. or what u can do is cut the plug (but leave enough so if u wanna reuse it) and wire it too a accessory fuse that turns on like the radio or cig lighter.
