Can find a Fire Wall hole in 92 SI.
Old Jan 12, 2005 | 02:11 PM
Prelude-TeCh's Avatar
Default Can't find a Fire Wall hole in 92 SI.
Can anyone tell me where I can find a hole in my Fire Wall to run a few wires through? Any help would be great.
Old Jan 12, 2005 | 02:17 PM
Jagan'92's Avatar
Default Re: Can't find a Fire Wall hole in 92 SI. (Prelude-TeCh)
there's a hole under the button in the top right corner of this screen:
https://honda-tech.com/zerothread?id=944732
Old Jan 13, 2005 | 11:55 AM
Default Re: Can't find a Fire Wall hole in 92 SI. (Jagan'92)
Ya thanks I already saw that but I was looking for another one.
Old Jan 13, 2005 | 01:15 PM
Dougs96SI's Avatar
what kind of wires are you trying to run?
Old Jan 13, 2005 | 02:03 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Can't find a Fire Wall hole in 92 SI. (Dougs96SI)
i just got the drill out and went to town above where the ecu mounts, worked for me.
Old Jan 13, 2005 | 02:42 PM
warrick's Avatar
Default Re: Can't find a Fire Wall hole in 92 SI. (PreIudeSI)
loosen the fuse box on the passenger side of the engine compartment. 1 or 2 10mm bolts and 2 clips. Move it to the side gently and behind it on the firewall is a rubber gromet. You will need to fish the wires through it from the engine compartment with a coat hanger of some sort. It is difficult but do able . If your car does not have A/C you could also use the ruber gromet that the A/C would have used . It should be below your ABS motor.
Good Luck
Old Jan 13, 2005 | 03:10 PM
yOnKiNaToR's Avatar
Default Re: Can't find a Fire Wall hole in 92 SI. (warrick)
there is also a hole underneath the intake pipe at about ecu level on the firewall, you can feed wires right in there and they will touch your ecu and then you can pull up your carpet and take off the big metal piece and route the wires under the carpet or anywhere you want them to go.
Old Jan 13, 2005 | 03:22 PM
Default Re: Can't find a Fire Wall hole in 92 SI. (yOnKiNaToR)
Awesome thanks for all the help guys!!!
Old Jan 13, 2005 | 05:14 PM
Slatelude's Avatar
plug under the fuse box under the hood 0-gauge fits beautifully, just drilled out the center of the plug to make it a gromet, bueno!
Old Jan 19, 2005 | 11:47 PM
Default Re: Can't find a Fire Wall hole in 92 SI. (Slatelude)
i found the one under the fuse box. looks doable to me. thanks for the help. If any one has any picture of this it would help for the archives.
Modified by Prelude-TeCh at 2:01 AM 1/20/2005
bboixtc
Apr 4, 2008 06:01 AM
jthrppel
Sep 29, 2004 08:56 AM
w.a.lude
Jul 31, 2004 09:33 PM
Fly1865
May 23, 2004 01:26 PM
miff
Apr 10, 2004 07:19 PM
