finally passed smog, now time for boost, checklist
well after failing smog about 8 times in 2 months, i passed smog. so now time to be boosted. just throwing out my setup just incase i forget something or helpful tips.
95 gsr chassis, 97 gsr motor, obd1 virgin p72 gsr ecu.
car has been reverted to stock for smog and only has a muffler.
garrett t3 SPECS ARE AN A/R OF .42 ON THE COMPRESSOR SIDE AND .48 ON THE TURBINE SIDE (whatever that means)
internal wastegate at about 7psi
RevHard replica cast iron manifold w/ 35/38mm wastegate flange
JohnnyRaceCar 6" Intercooler
Cartech Adjustable FMU
Tial 38mm WG w/ 6psi spring i believe
TurboXS Type S Bov
RevHard Downpipe
stealth mode performance turbo oil line kit
Walbro 255lph HP Fuel Pump
Boost Gauge
all i need to do is order piping. im going to reuse my injen cold air intake so i believe all i need are a few u-bends. order from jcwhitney.com?
gonna double check compression, and should i put on an exhaust first? or go boost then exhaust after? i know 3inch piping is best, but i was thinking of just getting a greddy sp2 or apex ws, tanabe hyper medallion etc (the stock muffler look w/ chrome housing). only plan to boost about 6lbs on stock internals so 2.5 piping wont hinder me much will it? plan to use fmu temp til i find a good local uberdata tuner.
so just do install, and just drive around and adjust fmu as needed? if i feel stutter or etc etc. what do i look for to know that the fmu is set correctly? thanks all. if any bay area people want to help, itd be appreciated
Modified by so simple at 7:00 AM 1/13/2005
TurboXS Type S Bov
RevHard Downpipe
Boost Gauge
c1 thats o2 sensor? hmm i dunno how to read turbo specs at all, i just went hey t3 is common size for honda's / manifolds. if i go uberdata, i have to upgrade injectors? dsm 450's?
is that a factory mopar turbo? i decided not to use this turbo on my stock ls because its way way too small.. also.. if it is the mopar verson the flange is a little different then the normal t3.. did you check to see if it will bolt up?
YodaIsGod
Aug 5, 2002 10:30 PM
