USDM vs. JDM
Old Jan 9, 2002 | 11:05 PM
Milhouse's Avatar
Default USDM vs. JDM
I know you guys are going to say JDM all the way....
but the USDM header allows you to easily replace the stock cat for emissions testing....
JDM you either have to buy an after market cat or replace your stock exhaust manifold and cat everytime you go through emission testing...
Opinions???????
Old Jan 9, 2002 | 11:15 PM
Spikey's Avatar
Default Re: USDM vs. JDM (Milhouse)
i notice u are from vancouver
with regards to emissions testing, ur car should only need to go thru aircare once every two years... and the word on the street is that aircare will be gone soon too
so either way, i wouldn't worry to much about the convenience of replacing the cat
Old Jan 9, 2002 | 11:22 PM
B2FiNiTY's Avatar
You can still get a highflow cat that will allow you to pass emissions.
Old Jan 9, 2002 | 11:33 PM
Milhouse's Avatar
Default Re: USDM vs. JDM (Spikey)
I have a friend that has a DC JDM header....
I know this is a wrong reason for a car nut to think twice about performance upgardes....but he said that he droped down to about 250kms on a tank now after removing the cat.
also.....i've heard high flow cats don't pass emmissions, plus they don't last very long....or so i've heard...
Old Jan 9, 2002 | 11:44 PM
Spikey's Avatar
I know a lot of people that use test pipes and still get 350km + per tank
how about your friend's driving style? it's possible that since getting the header, he drives more aggressively and thus has reduced mileage
besides emissions, the main drawbacks i see with test pipes or hi flow cats are the smell, and the longer warmup times. stock cats are designed to help warm up themselves and the engine faster to reduce emissions
as for high flow cats not passing emissions, i think that's probably rare... of course it has to be looked at case by case. if u'r concerned about the longevity of a hi flow cat, just go with a test pipe and swap in ur cat for aircare
Old Jan 9, 2002 | 11:53 PM
Milhouse's Avatar
Hey Spikey....
What about longevity of the engine???
If you put in a test pipe, your O2 sensor will read lean and richen up the fuel mixture....
isn't it bad to run rich all the time??
Old Jan 10, 2002 | 12:26 AM
B2FiNiTY's Avatar
Your mileage should INCREASE shouldn't it? Unless your on the throttle all the time. I'm pretty sure that the CEL won't affect how rich or lean your car runs.
Old Jan 10, 2002 | 12:39 AM
Toda Party's Avatar
Default Re: USDM vs. JDM (B2FiNiTY)
1 - i heard that most honda 4cyls can pass emissions w/ not cat? true false?
2- if the cel is on, and you are in safe mode, doesnt the ecu dump a lot of fuel?
Old Jan 10, 2002 | 01:30 AM
99ITR_SC's Avatar
Default Re: USDM vs. JDM (Toda Party)
my car failed aircare with a stock cat
Old Jan 10, 2002 | 04:00 AM
RagingAngel's Avatar
Hey Spikey....
where's sgT to squash this ? Hahahaa
I've been running my testpipe....for too long now and if anything I haven't noticed any change in fuel economy.... juss nice power increase...
ITR3189
Aug 1, 2007 09:13 PM
RS96
Jul 10, 2003 09:53 AM
2k1TypeR0610
Sep 28, 2001 08:16 AM
Toda Party
Sep 13, 2001 07:48 AM
Con-G
Jul 17, 2001 08:11 PM
