How long do you let your turbo car warmup?
Old Jan 12, 2005 | 06:22 AM
mchuang's Avatar
Default How long do you let your turbo car warmup?
The reason I ask is because most of the time I drive it cold at like 2000 rpm until it gets to normal operating temperatures. I dont like to stay in my apt parking lot in the morning while it is idling at 2000 rpm to warm up because neighbors be trippin
Old Jan 12, 2005 | 06:24 AM
m R g S r's Avatar
Default Re: How long do you let your turbo car warmup? (mchuang)
I do the same thing. I drive it cold to the deli every morning, and let it idle there. It's the same thing as driving with it cold when NA, as long as your only using partial throttle and not boostin it. . . .
Old Jan 12, 2005 | 06:27 AM
Rory Breaker's Avatar
Just like when it was NA...I get in, start it up, let it idle for maybe a minute or so, then go. Mine sits at about 1700rpm, then drops to 1500rpm after a minute. When it drops, I go. I just baby it under ~3500rpm until its fully warmed up.
Old Jan 12, 2005 | 06:36 AM
mattEG's Avatar
Default Re: How long do you let your turbo car warmup? (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">Just like when it was NA...I get in, start it up, let it idle for maybe a minute or so, then go. Mine sits at about 1700rpm, then drops to 1500rpm after a minute. When it drops, I go. I just baby it under ~3500rpm until its fully warmed up.</TD></TR></TABLE>
I do exactly what this fella does.
Old Jan 12, 2005 | 06:37 AM
PM-Performance's Avatar
when it was on the stock motor I used to let my ITR warm up for like 10mins maybe.
On the built motor I let it warm up much more on colder days becuase the cold idle maps were retarded rich for a while. So I usually let it warm up until it went into the 12's a/f at worst at idle.
Old Jan 12, 2005 | 06:55 AM
underpressure02's Avatar
I get it in start it pull out of my driveway and take it up to about 8000rpm's @ 10psi. That gets the heat flowing much better on these cold days.
Old Jan 12, 2005 | 07:05 AM
pitchblackeg's Avatar
Default Re: How long do you let your turbo car warmup? (underpressure02)
^^^ lol. yup. adquate warm up time.
Old Jan 12, 2005 | 07:06 AM
Johnyquest's Avatar
I let it run for like a minute or two w/o moving it, once the idle begins to drop to a reasonable idle I just drive. No beating or anything until full OT, but I just drive.
Matt
PS- I have nothing against boosting part throttle &lt;5 lbs or so even when it's cold. I've been doing it forever. I figure.. .factory turbo cars do it
Old Jan 12, 2005 | 07:09 AM
Sohc Driver's Avatar
Default Re: How long do you let your turbo car warmup? (Johnyquest)
I have a Greddy Water temp guage, and what I usually do is let it warm up to 40 degrees celcius. And that usually takes me about 3 1/2 minutes. However I don't boost until I get up to normal operating temperature which is 80 degrees celcius.
Khoi
Old Jan 12, 2005 | 07:25 AM
mchuang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">I get it in start it pull out of my driveway and take it up to about 8000rpm's @ 10psi. That gets the heat flowing much better on these cold days. </TD></TR></TABLE>
Hahaha
Old Jan 12, 2005 | 07:52 AM
93turbo16's Avatar
If its crazy cold I will let mine run for a good 3-5 minutes before even thinking about moving. Its nice to live in the country.
Old Jan 12, 2005 | 07:58 AM
racingfan's Avatar
Default Re: (93turbo16)
I let mine warmup till the normal operating temperatures.
Old Jan 12, 2005 | 08:37 AM
SOHC_MShue's Avatar
same here
Old Jan 12, 2005 | 09:26 AM
Bailhatch's Avatar
Default Re: How long do you let your turbo car warmup? (SOHC_MShue)
I let it idle for around 30sec then drive it lightly until the factory temp gauge is in the middle. This warms it up much faster than idling and gets the oil up to temp so it can do its job.
Old Jan 12, 2005 | 09:33 AM
Tony the Tiger's Avatar
I have a block heater, so my temps are partially warm when I start up the car. I let it sit for about 1 min and drive off until the temps are fully warm before putting load to the engine
Old Jan 12, 2005 | 10:02 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">
Matt
PS- I have nothing against boosting part throttle &lt;5 lbs or so even when it's cold. I've been doing it forever. I figure.. .factory turbo cars do it </TD></TR></TABLE>
And you are probally beating your motor to death. There is probally alot of blowby while its cold and boosting. Not fully expanded psitons = no good for boost.
Old Jan 12, 2005 | 10:19 AM
Finland's Avatar
I let it idle for about 1-2 minutes before driving, then I drive like a grandmother until the coolant temp gauge is normal and oil temp is about 140F, then I let all hell break loose..
Old Jan 12, 2005 | 10:20 AM
SdGSR01's Avatar
Default Re: How long do you let your turbo car warmup? (m R g S r)
I normally turn on the car lock my doors and go back inside to have my morning coffee, so about 5 min. I always warm it for at least 2-3 minutes though. Better safe than sorry for being in a rush.
B16Civic93
Mar 23, 2005 07:23 AM
rough_draft
Jan 12, 2005 11:12 AM
crx00
Mar 13, 2004 06:39 AM
el arbi
Apr 30, 2003 08:29 PM
