jdm h22 plug wires
Old Jan 12, 2005 | 04:44 AM
IMPORT JEDI's Avatar
Default jdm h22 plug wires
which plug wires do i need for a jdm h22.
Old Jan 12, 2005 | 05:12 AM
satan_srv's Avatar
Default Re: jdm h22 plug wires (IMPORTJEDI)
uhh...same as any H22a.
Old Jan 12, 2005 | 05:28 AM
Default Re: jdm h22 plug wires (satan_srv)
if i was that easy i would be done. i have tried 2 deffrent sets.they are to short
Old Jan 12, 2005 | 05:40 AM
satan_srv's Avatar
did you switch to a USDM external coil distributor?
Old Jan 12, 2005 | 05:44 AM
rpm95civic's Avatar
no
the jdm plug is alittle over 5inch all the plug wires we have gotten are 4 3/4 inch(the part that goes down and hooks to the plug)
Old Jan 12, 2005 | 06:35 AM
Adam.'s Avatar
Default Re: jdm h22 plug wires (rpm95civic)
I have a internal coil jdm h22, I ordered my plug wires for 92-96 prelude vtec.
Old Jan 12, 2005 | 09:53 AM
The Birdman's Avatar
if theyre too short like that theyre probably h23 wires, i tried them before, they wont reach all the way down
just go back to the company and make sure they know its 2.2 dohc vtec they mix it up with the 2.3 a lot because they think the 2.3 is the "best" or "top of the line" because its bigger.....
Old Jan 12, 2005 | 01:25 PM
SKDRCR's Avatar
Default Re: (jd3jdm)
It sounds like you got h23 wires instead of h22 wires
Old Jan 12, 2005 | 01:48 PM
vtec_crazy's Avatar
i got the same car as you,
u have to order 98 vtir wires for your h22a. we got internal coils.. and if you look at your engine date its porob 1998...
Old Jan 12, 2005 | 02:14 PM
Speedra500's Avatar
Default Re: jdm h22 plug wires (vtec_crazy)
I've had this problem a million times at advanced auto parts and autozone, they only have wires for f22s and h23s, a friend of mine that works there said their computer system only recognizes the h22 in 96, so you might want to try that.... or at least have them check and see if it is a different part number
Old Jan 12, 2005 | 02:27 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_crazy &raquo;</TD></TR><TR><TD CLASS="quote">at your engine date its porob 1998...
where is the engine date located at?
Old Jan 12, 2005 | 03:26 PM
vtec_crazy's Avatar
Default Re: jdm h22 plug wires (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
where is the engine date located at?</TD></TR></TABLE>
well on my car its on top of the motor on the firwall on the right hand side....
should tell you you vin number nad date etc...
Old Jan 13, 2005 | 01:23 AM
SKDRCR's Avatar
I was hoping you were referring to a place on the actual block
Old Jan 13, 2005 | 12:09 PM
vtec_crazy's Avatar
I was hoping you were referring to a place on the actual block </TD></TR></TABLE>
yep..
Old Jan 19, 2005 | 05:21 AM
lewta's Avatar
I had the same problem, they kept giving me wires to the F22....make sure you are getting the ones to the H22, had to go back twice.
Old Jan 19, 2005 | 07:47 AM
SearchBeforeUPost!'s Avatar
Default Re: jdm h22 plug wires (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">I've had this problem a million times at advanced auto parts and autozone, they only have wires for f22s and h23s, a friend of mine that works there said their computer system only recognizes the h22 in 96, so you might want to try that.... or at least have them check and see if it is a different part number</TD></TR></TABLE>
me too. Go with OEM honda wires for any h22a, they fit fine.
SiRTifiedacc
Feb 24, 2006 06:23 AM
ajmj
Oct 19, 2005 09:57 AM
sr20dettrex
Dec 17, 2004 12:57 PM
H22TurboNos
Jun 21, 2002 11:31 AM
