I cant seem to pass smog, how much fuel can I take out at idle safely
Old Jan 12, 2005 | 12:51 AM
Rywire's Avatar
Default I cant seem to pass smog, how much fuel can I take out at idle safely
I cant seem to pass smog, how much fuel can I take out at idle safely, I am gunna have a friend burn me an uberdata chip to try and get me through the BAR process.
Legally I can have 100 hc's at idle, and im at 300 right now. Im good in all the other tests, its just HC's at idle that are giving me troubles.
Ya, I have a idle/2,500 rpm test, weird huh...
New cat, and o2 were added, full tuneup, exc...
Ryan
Old Jan 12, 2005 | 10:25 AM
Rywire's Avatar
Default Re: I cant seem to pass smog, how much fuel can I take out at idle safely (droppedcrxsi)
bump
Old Jan 12, 2005 | 10:50 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
I had the same problem. If you have an FPR, lean it out slightly at idle. Also, use LOWER OCTANE fuel. The higher the octane, the harder it is to burn. This should fix your issue.
Old Jan 12, 2005 | 08:47 PM
Rywire's Avatar
Default Re: I cant seem to pass smog, how much fuel can I take out at idle safely (JDM_Ej)
You cant have a adj fpr for a REF inspection.
Old Jan 12, 2005 | 08:52 PM
Jim Truett's Avatar
A stock map with the closed loop enabled should pass fine.
Old Jan 12, 2005 | 09:41 PM
Rywire's Avatar
Default Re: I cant seem to pass smog, how much fuel can I take out at idle safely (Jim Truett)
could you explain more please. Thanks
Old Jan 13, 2005 | 04:44 PM
Rywire's Avatar
Up... im thinkin 15%?
Old Jan 13, 2005 | 05:18 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">could you explain more please. Thanks</TD></TR></TABLE>
Has your ECU been modified (chipped)? Basically, if you run the stock tune with stock fuel pressure, and all sensors are connected properly, the ECU will run in closed loop, and set the proper AFR on it's own. Do you have a modification that is not allowing the ECU to run in closed loop operation? Simply pulling fuel is not a good solution. If it goes lean, you will have high Nitrogen Oxides.
Old Jan 13, 2005 | 06:00 PM
Rywire's Avatar
Well they arent testin nox, and it will just be for the test only. Yes the ecu that I use for smog is a stock p72
Ryan
Old Jan 17, 2005 | 09:58 PM
sohczchf's Avatar
ok you mite think this is crazy but try some rubbing alcahol in the tank one bottle for your tank the shop i workd at in phoenix did this to a rangerover to get to pass and the do a dyno type test there
raramury
Mar 29, 2013 07:48 AM
CentralCalLude92
Jun 24, 2008 05:48 PM
Jdmprelude94
May 22, 2007 10:43 AM
ludecrasy87
Nov 24, 2006 10:36 PM
ludecrasy87
Nov 20, 2006 02:42 PM
