block guard removal
Old Jan 11, 2005 | 09:15 PM
mustbenu's Avatar
Default block guard removal
i recently purchased a rebuilt b18c motor
it has a nuformz block gaurd in it......
would i be able to take the head off and just remove the block guard and reinstall the head..
Old Jan 11, 2005 | 10:34 PM
mustbenu's Avatar
Default Re: block guard removal (mustbenu)
ttt
Old Jan 11, 2005 | 11:18 PM
KFBhonda's Avatar
if it was welded in then it's there to stay and even if it isn't i wouldn't want to yank it out if i was you. just my $0.02
why do you want it gone so bad?
Old Jan 11, 2005 | 11:20 PM
mustbenu's Avatar
Default Re: block guard removal (KFBhonda)
ive heard bad things about block guards
id rather be safe with out it....
im only planning on low boost anyways
so no need for it
Old Jan 16, 2005 | 09:00 PM
torqueless's Avatar
i have a few questions about block gaurd.
When you have a closed deck, does that just mean you have a block gaurd?
also wouldnt bg just create more heat?
Are block gaurds pointless if the block has been sleeved?
and what does honing a block mean?
What does having a block decked mean?
sorry to ask on this thread, but it looked like its over with anyway, and i didnt want to start my own over a couple questions.
Old Jan 17, 2005 | 06:54 AM
torqueless's Avatar
Default Re: block guard removal (torqueless)
bump
Old Jan 17, 2005 | 07:32 AM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torqueless &raquo;</TD></TR><TR><TD CLASS="quote">i have a few questions about block gaurd.
sorry to ask on this thread, but it looked like its over with anyway, and i didnt want to start my own over a couple questions.</TD></TR></TABLE>
1..closed deck can mean you have a blockguard although some motors came stock with a cast closed deck.
2. A blockguard if installed peoperly will be fine and not create any problems
3. IMO a blockguard is not necessary if the block has been sleeved
4. Honing the block is the process of applying a crooshatch pattern to the cylinder walls. This helps the rings form a good seal when they seat against the cylinder walls.
5. Decking a block is the process by which the block surface that mates with the head is machined level.
Hope this helps.
Old Jan 17, 2005 | 11:37 AM
torqueless's Avatar
Default Re: block guard removal (91civic)
thanks alot man
Old Jan 17, 2005 | 11:41 AM
GoFastMotorSports's Avatar
A correctly installed blockguard is good insurance for a motor. The problem is some people just hammer the guard in,and when they do that it moves the cylinder walls. The proper install is to sand it a little so it slides on.
eg:R
Apr 19, 2014 08:56 AM
Lewcis
Jul 29, 2004 09:19 PM
FOrSfEd
Feb 28, 2004 04:02 PM
Nextelbuddy
Feb 10, 2004 09:23 AM
