Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: Why is my car hesitating?
Guide to diagnose touble and recommended solutions.
94 accord hesitation on initial accel
I have a 94 accord lx. sohc no vtec. on acceleration from a stop, in any gear, the is a brief hesitation. almost like it is boging down then it goes fine.
i have a 95 ex v6 and have the same problem. it has been this way ever since i bought it at 87,000 miles. r u talking about when u first apply medium to hard acceleration it pauses for a fraction of a second and then pulls forward? it does this while i am moving at various speed and from a stop as long as medium to hard pressure is applied to gas pedal. that is how mines act. i always thought it was like this. how bout everybodies experience with this??? thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Staats0778 »</TD></TR><TR><TD CLASS="quote">I have a 94 accord lx. sohc no vtec. on acceleration from a stop, in any gear, the is a brief hesitation. almost like it is boging down then it goes fine. </TD></TR></TABLE>
If you are accelerating from a stop I'm hoping the ONLY gear you are in is 1st... but anyways, when was the last time you had a tune-up. spark plugs, wires, clean air filter (old factory filters can get nasty). How many miles are on your car? Check engine light?...
My guess would be EGR valves, they are a common problem...check this out:
http://home.comcast.net/~em-engineering/T2T013.pdf
A typical problem that the car hesitates or quivers during acceleration above 1800 rpms.
mine seems to bog on take off untill i hit like 2,000- 2,200 rpms ? could it also be the same thing and its running a little rich with a cel ,but the cel is for map sensor but i changed the map sensor and reset ecu but is still the same, and as soon as i hit those rpms my car feels like theres a sudden kick of power
