93 civic flasher keeps ticking???
Old Jan 11, 2005 | 04:30 PM
scdarksol's Avatar
Default 93 civic flasher keeps ticking???
sup guys, on my buddy's 93 civic ex coupe the flasher keeps ticking when the lights are on, I replaced the flasher with a new one and it's still doing the same thing, I'm clueless guys. Any help is appreciated!
Old Jan 11, 2005 | 04:31 PM
B2FiNiTY's Avatar
Default Re: 93 civic flasher keeps ticking??? (scdarksol)
Even when you are not signaling? Are the lights outside flashing?
Old Jan 11, 2005 | 04:34 PM
ej1 pilot's Avatar
Default Re: 93 civic flasher keeps ticking??? (B2FiNiTY)
please explain better
Old Jan 11, 2005 | 04:53 PM
scdarksol's Avatar
When you turn on the lights, the flasher (in fuse box), will keep ticking even when you not signaling, when you are signaling the ticking will stop, and just tick normal like it would when you put on your signal. I disconnected the headlight switch and it was still ticking. ?????
Old Jan 11, 2005 | 05:02 PM
b 1 6 a 2's Avatar
Bad signal relay, but since you changed it, that shouldnt be the problem. What about the signal switch itself? Is it shorted/defective?
Old Jan 11, 2005 | 05:26 PM
93civicsedan's Avatar
Default Re: ([civic])
check the bulbs if you havent already.
Old Jan 11, 2005 | 06:36 PM
alotawatts's Avatar
Try another relay ? Also ...trying to remember if these can plugged in backwards = goofy circuit ?
Old Jan 11, 2005 | 06:44 PM
backdraft's Avatar
I had the same thing happen to me in my hatch. It was the combo switch itself. Just switch out the lights and turn signal module and it should fix your problem. I know that this willl work. Good luck.
scdarksol's Avatar
nope, I disconnected the switch from the circuit and it still keeps on ticking. bulbs work fine, everything operates fine, really clueless now.
Old Jan 11, 2005 | 11:33 PM
backdraft's Avatar
Default Re: (scdarksol)
Don't know what to tell you, That was exactly what mine was doing and it was the hole combo switch. I unplugged it and took out the two screws and replaced it and it was all good after that. sorry.
TeggyTitan831
Nov 16, 2018 05:27 PM
Forcefedvtec
Feb 8, 2015 02:31 PM
Tyla12
Apr 6, 2010 09:06 AM
qwrty
Jul 23, 2008 04:18 PM
drummr6
Oct 13, 2005 02:52 PM
