CKP sensor please help!
Alright, I just swapped my gsr motor back in my integra. started it up. drove it around the block for about 10 minutes, drove fine but sluggish.
I"m getting a code 7 and 4. and I'm running obd-0 everything
Code 4 is what I'm stuck on and what I need help with.
I replaced the distributor with another working one and it's doing the same thing, will occasionally start but dies right away and it throws the code.
I reset the ecu a few times, it didn't help, I looked at everything and it all looks right and plugged in good and tight. I cracked open the ecu and that looks fine too.
I"m lost, and I need help with this pretty bad. please reply, or my msn and aim is G2Crash@aol.com. TIA
Well, if you've tried a new distributor, then what's left is to check the wiring from there to the ECU. On my '95 the CKP sensor wires are blue/green(shielded) & blue/yellow. (But I don't know if they used the same colors on earlier years?)
fast-rex
Jan 28, 2003 01:35 PM
fast-rex
Jan 27, 2003 04:53 AM
