replacing the valve cover gasket
Old Jan 11, 2005 | 03:02 PM
tkeaeifuwill's Avatar
Default replacing the valve cover gasket
just wondering if anyone knows a proper way to replace the valve cover gasket or a place for me to find steps in doing it correctly so i do everything in order. i have a 94 accord 2.2L Vtec
Old Jan 11, 2005 | 05:23 PM
integ6657's Avatar
Default Re: replacing the valve cover gasket (tkeaeifuwill)
Not very hard at all. There is no real "steps" to removal. First, remove the spark plugs. Then remove the bolts holding it on along with the grounding strap. Once its loose, just remove the old gasket and replace it with a new one. I like to put a little gasket sealer or hondabond on the four corners and where the distributor meets the cover. Also....while youve got it off, I would replace the small spark plug tube gaskets. There cheap and will be easily accessible while you have the valve cover off. Good luck.
FinzWake
Nov 23, 2015 07:55 PM
NayborhoodJohnny
Aug 19, 2011 10:23 PM
Tazragoon
Oct 19, 2006 01:53 PM
KOALA YUMMIES
Oct 29, 2002 06:44 PM
FSTRex
Oct 5, 2001 09:07 AM
