Mini me swap - Y8 Manifold using OBD-1 Wiring
Hey what's up? I know this probably has been answered a few times using search. However, this is my situation.
I have a Y8 head (manual) w/ Y8 injectors using the P28 ECU. Do I have to use OBD-1 Injectors and get the pigtail clips for them or can I use these injectors just fine with the manifold.
AIM: NeophyteEQ
Thanks in advance,
Jon
AIM: NeophyteEQ
Thanks in advance,
Jon
Hey coo coo. But i have a 88 CRX DX (w/ MPFI conversion). The clips on those don't fit the OBD-II injectors? How do I wire it up?
Thanks,
Jon
Thanks,
Jon
get a solderer and solder the corners inside the injector clips to match up with the obd2 injectors.
(youll know what im talkin bout when you look at it )
Hmm Yeah i know what ur talking about when soldering the plastic clips. I might just do that =P Anyways, but Ill probably want to run some OBDII clips in the future.
If anyone has some more info on this
Please feel free to post.
Thanks,
Jon
Please feel free to post.Thanks,
Jon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy »</TD></TR><TR><TD CLASS="quote">Hmm Yeah i know what ur talking about when soldering the plastic clips. I might just do that =P Anyways, but Ill probably want to run some OBDII clips in the future.
Thanks,
Jon</TD></TR></TABLE> im using the obd2 injectors with my obd0 clips(just like how i explained) if you do it my way you should have no trouble using obd1 too cause on the obd1 the injectors side has like edges that stick out, i just break em off and its compatable with my clips . Hope this helps .and you can use obd0 injectors if you ever want to switch back.
Thanks for the help guys. I guess Ill be needing some clips in the future.
If ya got any (4) OBD-II Injector clips or (4) OBD-O Injectors. Give me a tell and we can arrange something.
Looking for new O-rings for the injectors.
Thanks,
Jon
Thanks,
Jon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy »</TD></TR><TR><TD CLASS="quote">LOOKING TO BUY some OBD-O Injectors w/ clips...or OBD-II Injectors clips w/ WIRE!
-Jon</TD></TR></TABLE>
If your going to run obd0 injectors youll need a resistor box..
Yep i got the resistor box. Just looking for a new set of injectors. Unless u guys got some OBD-II clips to part out
1ludeEK
15
Mar 21, 2007 01:47 PM
iphatcrxi
Nov 14, 2006 10:09 AM
Wes90civic
Feb 22, 2004 07:25 AM
