Water Leak
Old Jan 11, 2005 | 12:47 PM
Wiseguy619's Avatar
Default Water Leak
I have some kind of leak in my trunk. I don't have anything in my trunk, it is completely empty. Has anybody ever drilled a hole in the bottom of their trunk to let water drain? Also, I have another leak that ends up getting my driverside floor wet, right by the lever to move the seat back and fourth. My floor is SOAKED. Any suggestions on how I could solve this problem.
Old Jan 11, 2005 | 12:53 PM
The Phil's Avatar
Default Re: Water Leak (ProjectPenny)
I have a leak like that in my trunk...its annoying as hell cuz it fried like 2 amps and some computer **** i left back there...i punched a hole under the spare tire mount and the water drains out fine now
Old Jan 11, 2005 | 12:54 PM
Hawkze_2.3's Avatar
It's probably from your sunroof drain tubes. Check them out and if the leak is coming from them, just tighten down the clamp or get better ones.
Old Jan 11, 2005 | 12:59 PM
Wiseguy619's Avatar
Default Re: Water Leak (Hawkze_2.3)
Should I just sit in my ride and have a homie pour water on my car? Thanks for the replies guys.
Old May 23, 2005 | 12:23 PM
honda95civic's Avatar
i drilled holes in my trunk...
but yea.. i layed in the trunk.. (its completely gutted with a tail light conversion) and my dad hosed down the car... found the one leak... fixed it. now on to the second.. good luck.. water travels in odd directions..
Old May 23, 2005 | 02:41 PM
Wiseguy619's Avatar
Default Re: Water Leak (honda95civic)
I found the one in my trunk. It was on the driverside behind the gas tank door. Above the rear bumper and below the quarter panel. I guess it was torn in some kind of preexisting incident from the original owner. I put some silicone to fill in the holes and it is holding up pretty good.
Old May 23, 2005 | 02:49 PM
prelude1897's Avatar
There are 2 drain plugs you can take out...I poped mine out and haven't had water in my trunk since....
Old May 24, 2005 | 04:40 AM
Default Re: Water Leak (prelude1897)
you might have water.. u just never see it cuz of the drain plug being removed...
Old Nov 11, 2006 | 03:49 PM
ethereal2pt2's Avatar
my car flooded from the floorboards up to an inch and a half. had rain for the past week. car was parked outside with a car cover.. there was water inside my spare tired compartment. drained it with the drain plugs. the whole inside of my car was wet. esp the rear seats and panels. the passenger side was more predominately flooded than the driver side. im hearing torn trunk seals and sunroof drain tubes.. i'll thoroughly check my seals but where is the drain tube located? i've looked for hours and hadn't gotten a clue. thanks.
beat
Jun 11, 2014 11:04 AM
x1aO
Mar 10, 2008 01:02 PM
hungsteR
Apr 11, 2002 11:06 AM
nEoMuGen
Aug 12, 2001 06:21 AM
AceP97
Jun 17, 2001 09:24 AM
