SRS light - question
Old Jan 11, 2005 | 12:07 PM
EK45VTi's Avatar
Default SRS light - question
Hi!
The car is 1996 Civic coupe D16Y7...
I want to remove my steering wheel with drivers airbag... I want to install Momo Millenium steering wheel...
I also want the passenger airbag to be DISABLED
My question is: HOW DO I GET RID OF SRS LIGHT???
Cos if I disconnect the connectors and leave the passenger airbag inside, I will get SRS light lit up all the time...
If I remove the SRS fuse, will that light go away?
Or any other way?
Or should I just pull out the SRS bulb...
Old Jan 11, 2005 | 12:17 PM
dantastic's Avatar
easiest thing: just pull the bulb
Old Jan 11, 2005 | 12:23 PM
EK45VTi's Avatar
Default Re: (dantastic)
But is there another way???
Like fuse or something cos if I ever want to sell the car, I will install back the OEM steering wheel and airbag...
And the truth is... I don't like pulling things out if not necessary
Old Jan 11, 2005 | 12:26 PM
BDogggUT34's Avatar
Default Re: (KKVTi)
i actually just pulled the plug on the back of the cluster. It would be easy to just plug it back in if you reinstalled the SRS system
Old Jan 11, 2005 | 12:31 PM
h22a_ej's Avatar
Default Re: SRS light - question (KKVTi)
yeah just pull out the cluster and disconnect the SRS wire from it...no biggy
Old Jan 11, 2005 | 01:11 PM
jlacoy82's Avatar
71.192.16.183
Default Re: SRS light - question (h22a_ej)
DO THIS AT YOUR OWN RISK, I'm not responsible for anything written in this post. As always, demonstrate caution when handling SRS parts/wires.
The service procedure for troubleshooting SRS lights in Hondas includes a step where you disconnect the 2P harness to the airbag, and in the wiring going TO THE SRS UNIT, NOT THE AIRBAG, install a 1.5 to 2.5 ohm resistor. This simulates to the SRS unit that the airbag is there and *should* kill the light if everything else is working properly.
So basically all you would do is disconnect the 2P connector on/just below the steering column, and the wiring that ran back into the dash to the SRS main unit, you would install a 1.5-2.5 ohm resistor to simulate to the SRS unit that an airbag is there.
For the passenger side airbag, you would also just disconnect the 2P harness behind the glovebox/radio area, and install a resistor. This way should you ever put anything back in, all you have to do is reconnect the 2 harnesses.
lamboextreme
10
Sep 24, 2007 06:09 PM
Rene M
Oct 11, 2006 02:43 PM
!xobile
Jan 24, 2006 09:01 AM
R-gonaut
Nov 7, 2002 07:47 PM
