how accurate are those air fuel ratio guages?
Old Jan 11, 2005 | 11:31 AM
rough_draft's Avatar
Default how accurate are those air fuel ratio guages?
i heard that they aren't that accurate. They are narrow band right? I heard nothign is really that accurate except a wideband. I'm interested in getting a a/f guage but i dont want to spend the money if its not worth it. Thanks guys
Old Jan 11, 2005 | 11:59 AM
555R's Avatar
Default Re: how accurate are those air fuel ratio guages? (omghi2ubbq)
well autometers arent accurate at all and would never tune by it
use a wideband like uego
or something thats setup with a dyno
Old Jan 11, 2005 | 08:29 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: how accurate are those air fuel ratio guages? (555R)
those A/F gauges you put on your car's Narrowband sensor are a joke.
narrowband O2's only work in closed loop.. once you give it enough gas, the car goes into open loop, and runs of fuel maps in the ECU.. then the car doens't give a **** about the O2, and its susually wrong.. so other than the blinking lights.. it doens't do ****.
for the money, ide want to invest in a wideband O2 and controller. its worth it, and will show you more results for longer.
Old Jan 11, 2005 | 08:48 PM
PrettyLude's Avatar
get a wideband
acuragtr
Sep 2, 2005 08:09 AM
one slow eg5
17
Nov 13, 2004 12:18 PM
nickromeo
Feb 8, 2004 06:43 PM
SOHCMAN
Jul 3, 2003 12:07 PM
acatak
Apr 14, 2003 08:16 AM
