idle bad need help
Old Jan 11, 2005 | 11:01 AM
blackek00's Avatar
Default idle bad need help
ok i got a 92 hatch vx
with a 95 gsr stock block
with a jg built head..jg throttle body and itr manifold
gsr with lsd tranny..
ok wen i first start up my car at cold the car idle really low like it bouts to die out.
driving on da freeway it fine but wen warmed up and i stop ne were at a complete stop the idle would jump to 1k.to 2500 up and down.what could be the problem. i tryed lookin for any vaccum leak but there is none.i was thinkin it could be the timeing?
let me know what yall think thanks.
Old Jan 11, 2005 | 11:33 AM
primeredbeast's Avatar
Default Re: idle bad need help (blackek00)
try to clean out the iacv on the back of the intake manifold it'll have like 2 12mm bolt take them out and clean the screen out try this
Old Jan 11, 2005 | 09:08 PM
PrettyLude's Avatar
Default Re: idle bad need help (primeredbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredbeast &raquo;</TD></TR><TR><TD CLASS="quote">try to clean out the iacv on the back of the intake manifold it'll have like 2 12mm bolt take them out and clean the screen out try this</TD></TR></TABLE>
Old Jan 12, 2005 | 03:31 PM
blackek00's Avatar
Default Re: idle bad need help (PrettyLude)
ok today i clean out the screen and no luck same thing.
.ever moring when i start up the car..da car idle low and bout to die..but wen it warms up the check engine light goes on. and it idle ok for awile until i drive for awile and put it in netual the idle bounce up from 1k to 2k. let me know what i need to do. thanks.
Old Jan 12, 2005 | 10:05 PM
PrettyLude's Avatar
what is the code for?
Old Jan 13, 2005 | 02:56 PM
blackek00's Avatar
Default Re: (PrettyLude)
code 15
Old Jan 13, 2005 | 07:41 PM
jgibbs's Avatar
Default Re: (blackek00)
hey i have a 90 integra gs and my idle does the same thing, i am going to try to fix it this weekend, i have read some threads on another site that say the fiav which is close to the iacv has a little white screw, that comes loose. open up the faiv and titen this screw and you shuold be alright, but other guys say if you tihgten it all the way the idle is still bad until you unscrew the white screw thing i full turn, once i try to fix my idle i will post again and tell you what worked for me good luck
Old Jan 13, 2005 | 09:04 PM
PrettyLude's Avatar
code 15 is ignition output, you sure that's the right code?
Old Jan 13, 2005 | 09:17 PM
elrandeeto's Avatar
Default Re: (jgibbs)
usaully if its the fitv the idle jumps only when cold , and ive never herd of backing it out a turn any one else ? i fixed my fitv and tightened it all the way and was fine . if its the fitv there are 3 - 10 mm bolts then two for the cover on the back oposite the coolant lines i forget what size they are
Old Jan 13, 2005 | 09:38 PM
PrettyLude's Avatar
maybe a size eight, but no i never heard of backing it out a turn
Old Jan 13, 2005 | 10:02 PM
blackek00's Avatar
im pretty sure it throwin code 15..
Old Jan 14, 2005 | 03:18 PM
jgibbs's Avatar
http://www.g2ic.com/forums/sho...+idle
hey this is another site not specifically for your car but i think the engine is about the same check this out, this is what i am going to do this weekend(use this guide to fix my car)
Old Jan 17, 2005 | 09:05 AM
jgibbs's Avatar
hey i fixed my idle last night, the problem for me happened to be the iacv screens were clogged and completely filthy, (step 6 of the writeup i gave you), idles smoothly now, just thought i'd tell you my problem
Old Jan 18, 2005 | 08:34 AM
blackek00's Avatar
hey thanks for all da info.i got it fixed it was da map sensor not hooked up...but i have another question...it seem like when i drive it hard my idle bounces up and down..friend say i might need a fuel pressure regulator ...i have itr manfold with 310 injector and aem fuel rail on a stock fuel pressure regulator. do i need to change it?
Old Jan 18, 2005 | 12:42 PM
jgibbs's Avatar
i dont know the answer to that question, but if you check out that site i sent you a link to earlier, i remember reading some threads about the same problem, i just dont know off the top o my head which ones, or what the fix was sry
Old Jan 18, 2005 | 03:49 PM
timdareez's Avatar
ya my needle jumps up n down sometimes as well add i got error code 14
error code 14 = IAC Sensor
Back of the intake manifold
check manual for correct readings ( Ohms )
Old Jan 19, 2005 | 04:26 PM
jgibbs's Avatar
Default Re: (timdareez)
i got a code 14 also i cleaned the screans of the iacv/eacv and it works fine now, adn now code 14 anymore, you unscrew to bolts, and spray carb cleanor and presto, your done lol, worked for me
bmanuhutu
Apr 26, 2010 07:41 AM
TegraD
May 15, 2009 02:55 PM
ctr status
Mar 2, 2009 08:11 PM
Shmolie
Jun 29, 2005 05:58 PM
NCPolo2000
Jul 11, 2004 08:26 AM
