Engine bogging when engaging gas pedal? Help!
Old Jan 11, 2005 | 10:55 AM
Rex_Ryder's Avatar
Default Engine bogging when engaging gas pedal? Help!
I was on my way to the gas station yesterday and when I got half way there the engine started to bog. Fuel pressure gauge is only reading about 12 psi. I'm assuming this is the problem. How do I determine if its the fuel pump is shot? If the fuel pump is shot would the gauge still have a reading? Or could it be something else? I'm new at this, hence the name, so I need some help from anyone who can offer. Thanks!
Old Jan 11, 2005 | 10:59 AM
AL ASPIRATED's Avatar
wat kind of pump do you have? wat kind of gauge do you have? where you completely empty on gas?
Old Jan 11, 2005 | 11:02 AM
Rex_Ryder's Avatar
Default Re: (AL ASPIRATED)
Not really sure on pump and gauge. But I wasn't completely empty on gas. I think it might just be a stock pump. It was running at about 37 psi before I left the house.
Old Jan 11, 2005 | 11:34 AM
primeredbeast's Avatar
Default Re: (Nu_At_It_CRX)
how low was the gas tank?
Old Jan 11, 2005 | 11:39 AM
Rex_Ryder's Avatar
Default Re: (primeredbeast)
In between 1/4 and empty.
Old Jan 11, 2005 | 11:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nu_At_It_CRX &raquo;</TD></TR><TR><TD CLASS="quote">Not really sure on pump and gauge. But I wasn't completely empty on gas. I think it might just be a stock pump. It was running at about 37 psi before I left the house. </TD></TR></TABLE>
where is da fuel pressure gauge mounted? it should be around 40psi if its around 12psi, then ur motor is not receiving enough fuel, it may be a fuel pump prob. or kink in da hoses. how about now after you filled the tank is it OK?
CeasarX
Honda CR-V & Element
Jul 15, 2018 05:34 PM
STREAMHAWAII
Jan 11, 2018 01:41 PM
traxxasx
Mar 16, 2010 10:21 AM
eL
37
Oct 20, 2005 03:27 PM
MR.OCHOA
Apr 8, 2003 07:26 AM
