rebuilding motor, what should be replaced?
Old Jan 11, 2005 | 08:45 AM
igo4bmx's Avatar
Default rebuilding motor, what should be replaced?
search engine sucking at the moment....
the motor is a d16y8 motor, with an unknown amount of miles.
i'm gonna rebuild it for boost, but want to know what gaskets and parts should be replaced.
i know i need,
timing belt and tensioner,
oil pump with gasket
water pump with gasket
what else?
is there anywhere i can get a complete gasket kit to replace all my gaskets?
Old Jan 11, 2005 | 08:48 AM
WAFFLES's Avatar
Default Re: rebuilding motor, what should be replaced? (igo4bmx)
Honda sells Upper and lower gasket kits(everything included)...some dealerships sell T-belt kits that include belt, tensioner pulley and spring and bolt.
might look into replacing the valve guides, just have them checked by the machine shop.
Old Jan 11, 2005 | 08:53 AM
respectblades's Avatar
Default Re: rebuilding motor, what should be replaced? (WAFFLES)
since your doing a complete rebuild your going to back to redo every gasket anyway
so might as well order and upper and lower gasket kit
Old Jan 11, 2005 | 08:58 AM
igo4bmx's Avatar
Default Re: rebuilding motor, what should be replaced? (respectblades)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by respectblades &raquo;</TD></TR><TR><TD CLASS="quote">since your doing a complete rebuild your going to back to redo every gasket anyway
so might as well order and upper and lower gasket kit</TD></TR></TABLE>
sounds good,
anything else i should look into?
Old Jan 11, 2005 | 11:20 AM
Cherry Blossom's Avatar
might wanna buy a more durable head gasket if going boost. but i hear people go with brand new oem gaskets and it works fine. arp headstuds to be on the safe side.
Old Jan 11, 2005 | 11:23 AM
igo4bmx's Avatar
Default Re: (Cherry Blossom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cherry Blossom &raquo;</TD></TR><TR><TD CLASS="quote">might wanna buy a more durable head gasket if going boost. but i hear people go with brand new oem gaskets and it works fine. arp headstuds to be on the safe side.</TD></TR></TABLE>
yeah i already bought arp headstuds and will be going with all oem gaskets except for a hondata IM gasket
Old Jan 11, 2005 | 11:33 AM
Soccerking3000's Avatar
Default Re: (igo4bmx)
they have rebuild kits, they cost around 350 bucks and they have everything, rings, pistons (if your not going with forged internals) this si the way to go
edit: for reference
http://cgi.ebay.com/ebaymotors...=WDVW
Old Jan 11, 2005 | 11:39 AM
igo4bmx's Avatar
Default Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">they have rebuild kits, they cost around 350 bucks and they have everything, rings, pistons (if your not going with forged internals) this si the way to go
edit: for reference
http://cgi.ebay.com/ebaymotors...=WDVW</TD></TR></TABLE>
nice buy too bad i have a y8
and also i have forged pistons and eagles...
also i would be concerned about the brand of those bearings they offer....
Old Jan 11, 2005 | 11:43 AM
well sicne you have forged internals already just get the gasket set, but i would say get a cometic headgasket as well
Old Jan 11, 2005 | 03:17 PM
jonjon149's Avatar
Do you know how to size your bearing? be careful!
Old Jan 11, 2005 | 03:32 PM
slammed_93_hatch's Avatar
Default Re: rebuilding motor, what should be replaced? (jonjon149)
im rebuilding a motor right now, and here is what im replacing.
piston
rods
rings
bearings
head studs
all gaskets
T-belt
water pump
oil pump
might be replace majority of the internal engine bolts also. Look at it this way, you have it apart so replace everything and anything you can so that way its as good as new when put back together and you have no worries
1990 CB7
Feb 27, 2017 11:40 AM
TallKyle
Feb 17, 2005 11:41 AM
mikebaglini
Nov 10, 2004 05:23 AM
navin
May 18, 2003 10:52 AM
94vtecmn
May 16, 2003 11:37 AM
