no fire on 3rd cylinder ?????????????
Old Jan 11, 2005 | 07:56 AM
imgonnalie2u's Avatar
Default no fire on 3rd cylinder ?????????????
gotta 1991 honda hatch stock 1.5 dont ask why thats still in there but i have no fire and 32 psi of compression. did compress check and found a burnt exhaust valve. question being will a new head take care of the problem?
Old Jan 11, 2005 | 08:05 AM
Filthy Focker!'s Avatar
Default Re: no fire on 3rd cylinder ????????????? (imgonnalie2u)
Depends on what test you used to check compression. Depends also on a visual inspection of that cylinder.
Very little compression will cause the fuel mixture to not ignite. Now, a burnt exaust valve, in my opinion, will not cause your compression to get that low...
But you may want to perform a leak down test to check for cylinder/piston damage.
Spray in a teaspoon of oil in the cylinder and measure compression. What happens is that the oil will sorta block any little gaps or holes that may let air escape. If you compression rate goes up, then you do have cylinder/piston damage. If not, then yes, a new head will probably cure your problem.
fs
stir_fry_boy
May 15, 2018 06:27 AM
Tyteg
May 16, 2007 07:30 AM
teefunk01
Nov 14, 2005 07:57 PM
Da1spaz247
Nov 4, 2005 07:57 PM
cxVtecC1
Feb 18, 2005 06:54 AM
