oil, coolant....
Old Jan 11, 2005 | 06:29 AM
JDMallTHEway's Avatar
Default oil, coolant....
i searched...
So i opened up my radiator when it was a bit too hot (stupid me)
but anyways, it exploded everywhere...
And my coolant looks more like oil than anything else...
I'm thinking blown headgasket. I have yet to check my oil.
Anything else it could be???
Old Jan 11, 2005 | 06:51 AM
flood's Avatar
Default Re: oil, coolant.... (JDMallTHEway)
if there was every any stop leak added it could be that.
Def check your oil and the underside of the oil cap. A really good way to tell is to do a compression test.
Old Jan 11, 2005 | 07:22 AM
Default Re: oil, coolant.... (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">if there was every any stop leak added it could be that.
Def check your oil and the underside of the oil cap. A really good way to tell is to do a compression test. </TD></TR></TABLE>
it is a possibility
my dads mechanic had it a bit go....
Old Jan 11, 2005 | 07:28 AM
also, it seems to be running normal.
flood's Avatar
I used some of that bars stop leak in my GF's car, its really dark brown almost black.
We had taken her car in for a water pump replacement and the mechanic thought for sure it was oil. It was the stop leak.
usually if a headgasket blows you will know it by how the car runs. It will miss and sputter. At least thats my expr. Also you would have noticed a loss in coolant.
Old Jan 11, 2005 | 07:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">I used some of that bars stop leak in my GF's car, its really dark brown almost black.
usually if a headgasket blows you will know it by how the car runs. It will miss and sputter. At least thats my expr. Also you would have noticed a loss in coolant. </TD></TR></TABLE>
hmm maybe he put some in, I'll have to find out.
It runs normal, i seem to be losing coolant, but theres no sputtering or misfiring....
Old Jan 11, 2005 | 08:08 AM
Filthy Focker!'s Avatar
In some cases, it is possible that your coolant simply changed color. I have seen this on Fords where the coolant was interacting the block casting. Of also, that "stop leak" crap was added to it.
If you are not experiencing any tell tale signs of a blown head gasket, i would not even look at that possibility. A simple flush of the system would be in order and then recheck the level and color in about 2 weeks.
fs
Old Jan 11, 2005 | 08:18 AM
Default Re: oil, coolant.... (filthy_shovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">In some cases, it is possible that your coolant simply changed color. I have seen this on Fords where the coolant was interacting the block casting. Of also, that "stop leak" crap was added to it.
fs</TD></TR></TABLE>
****.. my Dad's STUPID mechanic put that **** in there.
well better than a blown hg I suppose.....
looks like I'm a need a new radiator in a few years ha,
Old Jan 11, 2005 | 08:22 AM
DaX's Avatar
DaX
Loved
Community Favorite
Buy the prestone flush kit from AutoZone. Flush it once every two weeks for about 8 weeks and it should get most of that **** out of there. It's what I had to do.
I have since replaced the engine in the car, and I looked in the water pipe of the old engine and it was all nasty and rusty. Bar's stop leak is horrible stuff.
RoseFuneral
14
Mar 9, 2013 09:43 PM
hAtChBaCkFoReVeR
Nov 12, 2008 12:01 PM
blackeg
Dec 2, 2007 05:32 AM
ealex
Mar 2, 2005 09:53 AM
VtecDA9
Oct 7, 2003 07:57 AM
