GT30R: Update #2 I can see the light
Old Jan 11, 2005 | 12:01 AM
crazyitr's Avatar
Default GT30R: Update #2 I can see the light
I tried to put a link to my original post: https://honda-tech.com/zerothread?id=1044846, but it doesn't seem to work.
My project is nearing the time to start it up.
Dual Pass Custom Intercooler by S2F
Adel Wiggins Clamps from Burns Stainless
Closeup of Endtanks and RFL Blowoff Valve
Note 3" Downpipe with dump and vband
Another pic of Burn's Collector and Downpipe
Car should be up and running soon. Waiting for stainless a/c lines and a few other mods to be daily driveable
Old Jan 11, 2005 | 12:49 AM
Smokinsax's Avatar
The Boot
wow...that looks pretty crazy...
Old Jan 11, 2005 | 02:37 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: GT30R: Update #2 I can see the light (bruceleeroy)
Daaaaaaaaaaaaaaaaaaaamn.
TeH SeX!
Old Jan 11, 2005 | 02:49 AM
b00sted93Hatch's Avatar
Default Re: GT30R: Update #2 I can see the light (NightRider-gsR)
Set-up looks good. Quick question on the intercooler. Will it work properly with the way the end tanks are set-up? Wouldnt the air going in just go sraight into the other pipe?
Old Jan 11, 2005 | 03:02 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: GT30R: Update #2 I can see the light (b00sted93Hatch)
lol, my accord's beater turbo setup cost less than your clamps!
very nice looking though.
just curious where'd you get your clamps from and how much?? just curious if you found a cheaper place than what I've been able to find??
Old Jan 11, 2005 | 03:21 AM
johnmay19's Avatar
Default Re: GT30R: Update #2 I can see the light (stackz)
Very nice looking setup. Just make sure to wrap the turbine and downpipe, seem very close to the distributor.
Old Jan 11, 2005 | 03:54 AM
SE-Rawkus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Will it work properly with the way the end tanks are set-up? Wouldnt the air going in just go sraight into the other pipe?</TD></TR></TABLE>
It works fine. When the car is boosting...the whole system (IC & IC piping) has pressure. Boost is a fancy way of saying pressure
Old Jan 11, 2005 | 05:37 AM
turbosi03's Avatar
Default Re: GT30R: Update #2 I can see the light (SE-Rawkus)
thats an interesting setup... looks good
is there a divider in the end tank between the inlet/oulet? or are you really just relying on pressure rather then airflow?
Old Jan 11, 2005 | 05:53 AM
Drag_On's Avatar
Good thing I read the whole thread, I was about to ask you why you chose that manifold if you were going to ditch the AC anyways... Thumbs up to me for reading about the stainless steel lines..
That thing should RIP !!
Old Jan 11, 2005 | 05:58 AM
Turbocivic94's Avatar
Default Re: (Drag_On)
Nice looking setup
Old Jan 11, 2005 | 07:02 AM
USDM 4G VTEC's Avatar
what i dont like is the heat of the turbo its going to heat soak the charge pipes after the intercooler
Old Jan 11, 2005 | 07:03 AM
Bailhatch's Avatar
Default Re: (Turbocivic94)
What happens if the engine moves more than a 1/4"? Wont the pipes just rip apart? Got any pics of the turbo support(s)?
Modified by Bailhatch at 12:52 PM 1/11/2005
Old Jan 11, 2005 | 07:15 AM
Ekasey's Avatar
Default Re: (Bailhatch)
mmmmm yummmm wiggina clamps teehee
Old Jan 11, 2005 | 07:31 AM
Blitzkrieg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Set-up looks good. Quick question on the intercooler. Will it work properly with the way the end tanks are set-up? Wouldnt the air going in just go sraight into the other pipe?</TD></TR></TABLE>
Think of it as 3 end tanks. The shared one has a bulkhead in it so that they aren't connected. The hot charge flows in the 1 tank and goes thru half the core, then it makes a U turn and comes back thru the other half of the core and out thru the other half of the endtank. Imagine an intercooler that is half the width and twice the length, and that is what you have here.
Old Jan 11, 2005 | 07:33 AM
sohcT's Avatar
Default Re: GT30R: Update #2 I can see the light (crazyitr)
that is sick.
Old Jan 11, 2005 | 08:13 AM
redzcstandardhatch's Avatar
something different
the red tranny cracks me up (mine used to be red too!). thats one amazingly engineered setup.....beautiful. is it easy to dissasemble and stuff? looks very wild. the link to the old post isnt working...whats the engine setup like? forged? stock?
Old Jan 11, 2005 | 08:55 AM
95GSRTT
Guest
Posts: n/a
Default Re: (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">what i dont like is the heat of the turbo its going to heat soak the charge pipes after the intercooler</TD></TR></TABLE>
Old Jan 11, 2005 | 08:58 AM
Slick GS-R's Avatar
How's that for being unique!
Very suitable name!
Old Jan 11, 2005 | 09:11 AM
Triscuit's Avatar
it looks crazy packed in there
Old Jan 11, 2005 | 09:29 AM
b16boost's Avatar
Default Re: GT30R: Update #2 I can see the light (Ronin EG6)
That looks exceptional
Old Jan 11, 2005 | 09:55 AM
W O T's Avatar
Default Re: GT30R: Update #2 I can see the light (b16boost)
Do you have any idea how ******* loud that BOV is mounted outside your car?
DISGUSTINGLY LOUD!
Mine @ 16psi just DD kills people
But ya like stated above, that turbo is gonna heat up and your going to be heating your charge pipes, and maybe your distro and hood lol
Old Jan 11, 2005 | 10:09 AM
Ri5e's Avatar
My goodness, that is a sweet setup!
Everything looks meticulous and well put together. I don't think those pipes are going to blow off anytime soon
Old Jan 11, 2005 | 10:29 AM
b16 pwrd ek's Avatar
Old Jan 11, 2005 | 10:35 AM
TURBODC4TEG's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">wow...that looks pretty crazy...
what i was thinking, looks good
Old Jan 11, 2005 | 10:36 AM
Dsm634's Avatar
LOUD NOISES
Looks great.
