lower control arms
a no-name company does make an upper control arm camber kit for our accords and supposedly makes a rear lower control arm as well....i'm still thinking about testing out the upper control arm if their kit will allow me to increase negative camber...in fact, you can help me if you want
http://www.truckn-store.com/pr...=1833
if you wanna help me, i just want to confirm that their front upper control arms will be able to increase negative camber instead of correcting it...i need to make sure before i spend the money to test those out and review
i woudn't trust those no name companies especially when it comes to suspension. i would stick to companies line spc, ingalls, sprint, etc etc. for the back i'm just gonna do the washer trick.
Dont think any good bling bling aluminum arms for any accord yet.
but becareful when you choicing it, most of the tuner(blue, red, silver, bling) LCA are made of aluminum. Under overwhelming stress(not from normal use i assume) the aluminum would crank and break into two piece. The stock steel piece would just bend, much safer than a wheel or two sling out
kamikazie
10
Jan 10, 2013 08:44 PM
he told you LOL
