multiple problems
i was driving down the road and it felt like my engine just started losing power for some reason...its happened twice so far. then i had major brake dust in the rear from my drums...i thought my ebrake cable was sticking causing the rear to wear prematurely propogating the dust...
i also thought that this maybe the reason the engine felt like it was losing power...iunbolted the ebrake bracket under the armrest for something and i didnt move ne thing...i bolted it back down and thys seems to be happening..coincidence maybe?
finally my clock is dim as hell and kinda fades out on the road...i took it out of my old eg and it worked fine in there...it faded out at the same time the engine felt as if it lost power...sounds serious? ne thoughts
your drums might be sticking you need to get back there and pull the drum off and see whats binding them up if the car sat for a while its a little rusty you might have a bad alternator or a bad ground to your motor
worked for me
worked for me
it sounds like your engine is losing power due to some kind of power problem I would say run through your groundsand make sure they are clean, and clean your terminals really well.
the brakes aren't sticking and the engine just ran strong when i took it for a 50 min test drive thru some back roads...the clock is still dim as hell...maybe its just the daylight that makes it seem dim...im going to add a capacitor to my stereo that i have laying around...maybe that'll help a lil
yeah I've made those thing's out of the ground wire that they sell at the stereo store, just get the little connectors and bolst them down from the eng to the body, that **** helps your idle and makes your lights alittle brighter. good luck
cloudconnected85
21
Dec 6, 2010 07:49 PM
Regular Series
Audio / Security / Video
Jun 10, 2003 10:58 AM
