which ecu to run on a new motor???
Old Jan 10, 2005 | 09:21 PM
EKtypeRhaTcH's Avatar
Default which ecu to run on a new motor???
hey guys i tried searching but no results show up. well my setup is this:
b18c1 block(stock)
type r head with mild headwork(port and polish from portflow)
thats basically it, now what ecu do i run to break it in? will a ob1 gsr ecu be cool? let me know hybrid guys
Old Jan 10, 2005 | 09:22 PM
i was also wondering if the secondary butterfly will have any effect on the ecu
Old Jan 10, 2005 | 10:07 PM
anybody?>??
Old Jan 10, 2005 | 10:13 PM
screen_name's Avatar
Default Re: (EKtypeRhaTcH)
just get whatever u have chipped, ur going to need something with a high rev limiter anyways
Old Jan 10, 2005 | 10:16 PM
so is the gsr ecu cool to break in the motor with? i will go p28/hondata later but dont i use a stock ecu for the break in period?
Old Jan 10, 2005 | 10:17 PM
didnt really answer the question, i dont have a chipped ecu but i do have a gsr ecu and a virgin p28
Old Jan 10, 2005 | 10:24 PM
BlueIntegraBoy's Avatar
How soon will be you able to chip the P28? If it's not long, the P72 should be ok until then.
Old Jan 10, 2005 | 10:44 PM
not for a while im more worried about the break in "period" i know im supposed to run whatever is closest to my setup so i was thinking gsr or type r but i have a chance to get a gsr ecu from a friend
Old Jan 10, 2005 | 10:49 PM
VTiVTo8000rpm's Avatar
ITR ecu 8900 rpm
Old Jan 10, 2005 | 10:57 PM
spankey167's Avatar
Default Re: which ecu to run on a new motor??? (EKtypeRhaTcH)
run a chipped p28 ecu. the gsr ecu will only recognize the dual butterflys while you are running a single vtec engaement with the type r head. Probably wouldn't run too well. i have a b18c1 with a skunk2 IM and im running a chipped p28.
Old Jan 10, 2005 | 11:01 PM
i know the chipped p28 is best choice but i dont have the funds to get it chipped, will it hurt the motor like running too rich or lean with the gsr ecu???
1998GsRIntegra
Aug 10, 2010 11:34 AM
speed_demon018
Jun 4, 2009 02:05 PM
tealchief
Engine Management and Tuning
Feb 9, 2009 07:47 AM
hondaEg_808
Mar 25, 2008 11:10 PM
IGotVTECyo
Sep 4, 2005 08:46 AM
