A very Quick Prelude JDM H22 Question
Hi,
Does a H22a engine mean its from a Fifth Gen ??
Thats what i gather from here :
http://www.streettuners.com/cu...elude
So if im buying a H22a engine is it from 5th Gen or are there 4th Gen H22a too.
Im talking Japanese engines only.
Also if anyone knows If im getting a JDM swap for my Honda Prelude H23 Si and its a forth Gen Vtec Engine will i need to change wiring harness ???
thanksalot
thanksalot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OzWolfbane »</TD></TR><TR><TD CLASS="quote">Hi,
thanksalot</TD></TR></TABLE>
H22a means it's a JDM DOHC VTEC motor.
they come from both 4th and 5th gen ludes. re-use your h23a1 engine harness and add VTEC wires as needed.
side note: any honda/acura(technically, there's no acura in Japan
) that has no alpha/numeric number after the 2nd alpha, then it's JDM
examples JDM = h22a, b16a, b16b, b18c, etc.
USDM= h22a1, h22a4, b16a2, b16a3, b18c5, b18c1, etc.
what would help you A LOT is if you read the FAQ thread that is stickied above the rest of the threads.
and if you can't find it here it is:
https://honda-tech.com/zerothread?id=689805
they come from both 4th and 5th gen ludes. re-use your h23a1 engine harness and add VTEC wires as needed. side note: any honda/acura(technically, there's no acura in Japan
) that has no alpha/numeric number after the 2nd alpha, then it's JDMexamples JDM = h22a, b16a, b16b, b18c, etc.
yeh i have read that just that tuner site confused me i thought H22a only came from 5th Gen as thats what the website showed....
also another Question...where does this go :
http://cgi.ebay.com/ebaymotors...&rd=1
http://cgi.ebay.com/ebaymotors...&rd=1</TD></TR></TABLE>
It's a cam seal, it goes on the side of your valve cover
between the vc and the head.
MadCityLude
Sep 22, 2006 09:45 AM
