radiator problems
Old Jan 9, 2002 | 03:51 PM
EGh22aEG's Avatar
Default radiator problems
my radiator has a hole in it which my friend patched up for me. i put coolant and water in there and the engine still gets real hot after a few minutes and smoke starts coming out of the radiator someone told me it might be the temperature clamp or something does anyone know what is wrong?
Old Jan 9, 2002 | 04:12 PM
rainforest's Avatar
Default Re: radiator problems (esp169)
yeah not to be a *** but if you have a hole in your radiator it might be a good idea to get a new radiator. or at least jb weld it.
Old Jan 9, 2002 | 06:16 PM
EGh22aEG's Avatar
Default Re: radiator problems (rainforest)
i just ordered a new radiator tonight but i was wondering if anything else could be causing the problem
Old Jan 9, 2002 | 06:28 PM
Jared's Avatar
steam out of the radiator is normal if you have the cap off, otherwise, causes for over heating could be air in the system since you did have a hole in the radiator, a stuck thermostat, or a fan that isn't cutting on.
Old Jan 9, 2002 | 06:37 PM
civicturbo's Avatar
Jared is correct and you might also have overheated when you got the hole initially and cracked the head.
Change or repair the radiator first. A good radiator shop might be able to repair the one you have by changing the tank that was damaged (depending where the hole is).
sdinteg
Jun 1, 2010 11:26 PM
dwn2earth922
Sep 12, 2009 10:00 AM
vxtirent08
Mar 20, 2008 10:36 AM
tkHBseries
Feb 19, 2005 06:48 PM
BluLuder
Jul 29, 2002 11:29 AM
