any way of increasing the mpg?
i have a 5th gen base with about 97k miles on it. i was wondering if there is any way to improve the miles per gallon of it. i usually drive conservatively and shift at every 10mph intervals. i dont know for sure how many miles i get per gallon, but i have calculated about 240 miles on one full tank of gas. any help would be appreciated. sorry if this topic has already been discussed.
get an engine management system such as hondata or aem and raise your compression with type s pistons. then have it dyno tuned. intake header and ehaust will help also along with a light weight flywheel and wheels.
Use 91 gas only, not 92 or 93 or 94, and get a tune-up you are getting really crappy gas mileage. The prelude has a 15.4 gallon tank, at the rated 22/26 (27?) even in city driving you should be able to hit 350 miles.
My built/tuned motor could still get 27mpg...
when is the last time you did cap/rotor/plugs? plug wires?
nah dood, i feel u too
5th gen lude too
full tank 230-250maxed !
it is crazy that lude suck in so much gas.
I been tryin to figure out why I can only get that much, mine is a 98 lude sh , with 67k mils on it... damn man, just this week my gas went out again... 220.... :\
5th gen lude too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeez »</TD></TR><TR><TD CLASS="quote">240 for a whole tank? sounds low for "conservative" driving, what type of gas are you using? and mods? stay out of vtec and your gas will last. </TD></TR></TABLE>
i have headers, short ram, exhaust
i use unleaded plus (octane 89 i believe)
in my short three months of owning my lude, i've hit vtec once. i stay away from that thing because it eats gas. no, i don't race.
i took a trip with 4 people and a trunk full of **** i got 407 miles on a tank but i was outa my mind when the light went on i was in the middle of no where. (car was mostly stock).
But now i get about 250 to 300 on a tank of 92 oct.
Holy crap, i got a tuneup like 5k ago and i still only get about 290 a tank!
Maybe its my auto though, that tranny is nothing but trouble.....
4th gen. run on 93 ocatane. i get like 200 miles a tank... drive pretty normal.. little heavy on the gas sometimes. average highway speed is around 60-70. local around 30's.. i have no idea where all my ****** gas is going. not in vtec most of the time ethier. somethins not tuned rite i think.
a few things:
1) best i've done is 302 miles out of my tank, that was 11.9 gallons of gas (you do the math) but i avg about 280 with a stock engine and i drive like a bat outta hell....sometimes i get less, sometimes i get more....hondas are quite touchy....oh yeah and i use 87 octane because i'm poor....put 91 in about once every other month
2) you'll get better mileage with better oil (right after a change, better brand, etc) among other things....if you're shifting every 10mph, i'd hate to be the guy behind you....cuz that means you're not getting above 2500rpm
3) i'm really not sure where 15.4 gallons is the size of the tank, when i'm on E with a light screaming at me after 11.5 gallons
hope this info helps....good luck
omg... i shift so fast , it is not even funny cuz i have a loud *** exhaust
the sooner i get to 5th gear, the lesser the sound, i didn't installed it, got the car with exhaust on, and my car is STOCK 5spd !
220mils is not normal.....
btw wat should i tune up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OxYi »</TD></TR><TR><TD CLASS="quote">omg... i shift so fast , it is not even funny cuz i have a loud *** exhaust
the sooner i get to 5th gear, the lesser the sound, i didn't installed it, got the car with exhaust on, and my car is STOCK 5spd ! </TD></TR></TABLE>
lol i have a greddy evo2 or an knockoff or something and its loud (i think). i shift fast too to avoid the sound. i might look for a quieter exhaust one day when i have money to spare because i spend so much on gas right now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kronn 98SH »</TD></TR><TR><TD CLASS="quote">a few things:
1if you're shifting every 10mph, i'd hate to be the guy behind you....cuz that means you're not getting above 2500rpm
lol that's right. i feel bad for cars behind me too but conserving fuel is more important than their happiness.
wow, your cars are bad off.
I get 388 gallons per tank at fast highway cruising (4krpm), and my tank is 14.9 gallons... or is it 13.9 gallons on the fourth gen?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">Use 91 gas only, not 92 or 93 or 94, and get a tune-up you are getting really crappy gas mileage.</TD></TR></TABLE>
Joel, why is it that a higher octane will burn more gas?
You could start by using the proper gas for your car. You are using 89 octane...when 91 is recommended for the car...if the knock sensor starts pulling timing and changing fuel maps to compensate...it's entirely likely you're getting *** mileage. Buy the real gas, and let us know how it goes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">You could start by using the proper gas for your car. You are using 89 octane...when 91 is recommended for the car...if the knock sensor starts pulling timing and changing fuel maps to compensate...it's entirely likely you're getting *** mileage. Buy the real gas, and let us know how it goes.</TD></TR></TABLE>
see post above
see post above
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion »</TD></TR><TR><TD CLASS="quote">Woah, so buying 93oct V-power is really hurting my gas mileage?</TD></TR></TABLE>
definitely.
octane too low = hot - detonation - engine compensates to shitty mode
octane too high = cold - unburnt fuel - no compensation just wasted gas
see that's the other side of the spectrum, which can be just as inefficient. Too much octane and your car has a hard time igniting the mixture, and will tend to leave more unburnt fuel, and resulting shitty performance, sluggish acceleration, bad MPG.
I remember when my VTEC was stock I ran 94 and I always had this hesitation every 500rpms or so under WOT acceleration. I ran it down to empty and tried a little experiment and bought 91. Problem never returned, then I looked into it and figured out what happened.
high-octane is all hype, they claim great mileage and performance, but it is only true if you can advance ignition timing and raise engine compression to take advantage of it.
You should always run the recommend octane, as the maps were designed for it, unless you have changed timing/compression to warrant it.
definitely.
You should always run the recommend octane, as the maps were designed for it, unless you have changed timing/compression to warrant it.</TD></TR></TABLE>
That's good to know
That's good to know
Not really because the higher octane you get, you are also getting a fuel preservative that has been added to the fuel that will make it last longer than the lower octane gas.
I use 93 octane and it is the sht
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI »</TD></TR><TR><TD CLASS="quote">
care to elaborate? last longer?? last longer at what?
</TD></TR></TABLE>care to elaborate? last longer?? last longer at what?
