Water damage in engine
Old Jan 10, 2005 | 05:50 PM
mikael's Avatar
Default Water damage in engine
Hello everyone.
I have a 2000 Civic SI, and last night while driving through a puddle my engine died (AEM cold-air sucked up some water). I was unable to restart both last night and this morning. The car was towed home at which point I took out the spark plugs and turned it over to get any water out of the cylinders. There was quite a bit of water that came out. I put the plugs back in but still nothing. The car will not even turn over anymore with or without a jump start, the starter just clicks. I fear the stall out last night due to water in the cylinders might have bent a rod, or worse somehow seized the engine altogether. I tried to manually turn the crankshaft, but it will not turn. Has anyone had a problem similar to this, or does anyone have advise on what else I can do? Thanks in advance.
Mikael
Old Jan 10, 2005 | 05:52 PM
doublejz's Avatar
Default Re: Water damage in engine (mikael)
sounds like another case of hydrolock, rip it apart and see what you did.
Old Jan 10, 2005 | 05:54 PM
DohcSide's Avatar
im sorry you have no chance of saving your motor
it is possible to restart your motor by letting it sit for a while then jump start and start up your car but about a couple of days later your engine will explode literally.
Again your motor is dead and you cant salvege it from what i say form experience from above.
Old Jan 10, 2005 | 05:56 PM
Lord Helmet's Avatar
rebuild time or replacement time
JDM-97CX's Avatar
Did you pull the motor? Was is still hooked up to the tranny when you tried to spin it by hand? If so was it in neutral? Were the accessory belts removed?
I think you might be headed toward a minor rebuild. Hopefully I am incorrect.
Good luck.
2hondas_noluck
May 18, 2011 09:13 AM
jscrib
Sep 26, 2010 04:42 PM
hafaadaiteg
Aug 28, 2007 07:21 PM
guero2517
25
Apr 2, 2004 12:21 PM
Nameless RB26
Oct 7, 2002 05:56 PM
