Need Help please! How do I remove aftermarket cd player? I'm trying to install antenna...
Title says it all---I have a 1993 Civic CX with a broken antenna. I am trying to install the new one, but I cannot get behind the CD player, which is an Alpine unit. I know there has to be some way to slide it out just enough so I can get to the back...how do I do it? Thank you!
94<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyWash1 »</TD></TR><TR><TD CLASS="quote">Title says it all---I have a 1993 Civic CX with a broken antenna. I am trying to install the new one, but I cannot get behind the CD player, which is an Alpine unit. I know there has to be some way to slide it out just enough so I can get to the back...how do I do it? Thank you!</TD></TR></TABLE> Remove the trim around the Alpines faseplate and on the left and right side you will see the retainer pins, lift them up 1/2 way and pull HU out, if the install was right and a backbrace was installed, you will have to get to the back of the HU go to http://www.installdr.com for OEM HU removel, [same for the Alpine if its backbraced like it should be]
