Cleaning fuel injectors?
Overall, not necessary if you buy your gas from a reputable station. You can, if you want, use injector cleaner that is added to your fuel tank. Chevron Techron is a very good product.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist »</TD></TR><TR><TD CLASS="quote">Overall, not necessary if you buy your gas from a reputable station. You can, if you want, use injector cleaner that is added to your fuel tank. Chevron Techron is a very good product.</TD></TR></TABLE>
yes, chevron is good stuff.
most of the EFI honda can go way over 200K without having to have the injectors cleaned. You probably do not need a new set, if you insisted, take it out and have the pro cleaned it for you. They will clean your injectors(which u cannot do it yourself, no, they are not using those 2.99 injector cleaner
) and return it to you.
) and return it to you.Thread
movingIIshadow
30
Feb 29, 2020 07:36 AM
EK45VTi
10
Sep 21, 2004 07:03 PM
