Wideband / Narrowband conections, use and settings with Hondata Urgent Help Needed
Old Jan 10, 2005 | 11:44 AM
dariusz's Avatar
Default Wideband / Narrowband conections, use and settings with Hondata Urgent Help Needed
I have a Hondata S200 and a Wideband that have a output from 0.5v (11.0 AFR) to 3.5v (17.0 AFR) full lineal (use the same Bosh sensor as the PLX, it is the AEM gauge type). My questions are regarding 2 points:
1) In 2 different places say about the resistor that need to be connect between the +12v and ground cable that the ECU don't have the "O2 heater error", but in one say a 20 Ohm 1Watt resistor and in the other say 1 KOhm 1/4 Watt resistor (an example of this differents is in the tutorial from Hondata and PLX to connect the PLX). What is the true value?
2) I know that I can connect the Wideband output to my Hondata (S200) to the original O2 imput (the original is 0 to 1 V and the new is 0.5 to 3.5 V) to tuning using the lambda tables, etc. But my questions is regard if I can make this conection permanent, in other words can I use this 0.5 / 3.5 V imput in my ECU in a permanent conection and have in example the Close Loop ON (and all the functionality of the ECU using the target voltage in 2.0V in example for 14.5 AFR), or I need to have the original O2 sensor and use the Wideband only for tunning?
All help is realy apreciated, thanks in advance,
Dariusz
Old Jan 10, 2005 | 01:41 PM
dariusz's Avatar
Default Re: Wideband / Narrowband conections, use and settings with Hondata Urgent Help Needed (dariusz)
No one have opinion or know the ansver?
Old Jan 11, 2005 | 12:02 PM
dariusz's Avatar
Is increible and frustrating that to "children posts" (what is the best color, is my wheels pretty. etc.) is possible to see 50 ansvers in 2 days, but for a real post no one ansver
Old Jan 11, 2005 | 12:35 PM
civicross's Avatar
http://www.hondata.com/techwidebandtuning.html
JacobMagner
Jul 9, 2008 06:27 AM
em2power
Honda Civic (2001 - 2005)
Feb 13, 2008 10:06 AM
GreddySi99
Sep 27, 2003 05:39 PM
marklamond
Aug 15, 2002 09:46 AM
