Thermostat Ground HELP: Accord 5th LX : H22A Swap
Old Jan 10, 2005 | 09:22 AM
hyperB16Turbo's Avatar
Default Thermostat Ground HELP: Accord 5th LX : H22A Swap
Hi, I did some searches and didn't find help relating to the problem I am having.
I have a 95 LX Accord swapping a H22A. My question is my stock LX harness did not come with the Thermostat Ground. The car cranks and wouldn't start.
Will someone provide me information on the Thermostat Ground in terms of wiring.
If I were to add the thermo ground what do I need to do.
Thanks in advance.
Zy
Old Jan 11, 2005 | 03:45 AM
zeroice's Avatar
Default Re: Thermostat Ground HELP: Accord 5th LX : H22A Swap (hyperB16Turbo)
when i trouble shoot my car when i forgot to hook up the thermo ground i grabed some jumper cables and hooked it to the thermostat and to the negative cable on the battery and it worked, also tried touching it to any metal part of the body really and everywhere i tried it worked so just run a say 12g or up wire from the thermostat and ground it to the body should be good to go.. Unsrew one of the bolts holding the thermostat on, slide the wire on the bolt then screw it back on then ground it to the body and your good to go...
Old Mar 10, 2005 | 04:59 PM
JDMHatch101's Avatar
Default Re: Thermostat Ground HELP: Accord 5th LX : H22A Swap (zeroice)
HEY MAN CAN YOU TAKE A PIC OF WHAT YOUR TALKING ABOUT?
Nisif
Jan 28, 2020 10:53 AM
accordh22aj
Mar 5, 2012 10:19 AM
Honda Sport
Jul 28, 2007 03:58 PM
quikrpm'z
Jul 27, 2005 12:01 PM
brian2903
Nov 4, 2003 06:43 AM
