02 vw turbo for free what should i do
Old Jan 10, 2005 | 09:11 AM
jspresso's Avatar
Default 02 vw turbo for free what should i do
im running a mini me swap d15b7 block with z6 head with ecu + tranny and my friend is driving a 02 gti and just bought a bigger turbo for his car and is giving me his old setup, has anyone ever put a turbo from a vw on a honda? i havent heard anything on this topic and i did searcha lil and no dice. if itll work what header whould i need? and other parts and so on and so forth?
thanks guys
Old Jan 10, 2005 | 09:13 AM
showtymers619's Avatar
* B A N N E D *
Default Re: 02 vw turbo for free what should i do (jspresso)
ask in the FI section
Old Jan 10, 2005 | 09:16 AM
Teggys1ClnDA's Avatar
i <3 git's. mmmmmmm.
Old Jan 10, 2005 | 09:17 AM
snoochtodanooch's Avatar
i am sure the turbo itself will work fine, its more of finding the proper manifold and or flanges to make everything mate up properly.
Old Jan 10, 2005 | 09:20 AM
mattEG's Avatar
those turbos are quite small i believe... may not be suited to your setup.. i forget the manufacturer name.. kki or iki or something
there was a post about them in the FI forum a while ago.
Old Jan 10, 2005 | 09:51 AM
teknoracing's Avatar
Default Re: (mattEG)
Let me chime in here. The 02 VW probably had a K03 sport turbo. Thats what i have on my 04. The turbo is quite small and the max HP most people get out of it is 230-240 with every bolt on out there and high 13 low 14's on the 1/4 mile. Of course the GTi's are heavy *** pigs, almost 3000lbs. I am swapping my turbo out for a T3/T4 setup though. Max PSI is about 22-23 and its efficiency range is about 17 -18 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspresso &raquo;</TD></TR><TR><TD CLASS="quote"> has anyone ever put a turbo from a vw on a honda? . if itll work what header whould i need? thanks guys</TD></TR></TABLE> Header and turbo =
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">i am sure the turbo itself will work fine, its more of finding the proper manifold and or flanges to make everything mate up properly. </TD></TR></TABLE> IMO its not worth it, sure the turbo is free but how much fabrication will it take. Just buy a basic turbo kit, cheaper in the long run.
Old Jan 10, 2005 | 10:22 AM
Ghetto Civic HX's Avatar
I love to drive
Default Re: (teknoracing)
If you're dead set on it, check out http://www.homemadeturbo.com
But I think it would be cheaper and easier to just buy a kit
hondaEg_808
May 21, 2010 09:53 PM
1000kg88hb
Mar 12, 2007 01:01 PM
jspresso
Jan 11, 2005 10:30 PM
RACINTWEEK
Dec 30, 2004 12:57 PM
Fa-Q Racing
Mar 29, 2003 12:16 PM
