is sleeving the block bad for your pistons?
Old Jan 10, 2005 | 09:02 AM
myDC4rox's Avatar
Default is sleeving the block bad for your pistons?
hey im wondering if u sleeve ur block, will it wear out ur pistons sooner? and what kinda diff. does it make on the engine if the block is sleeved? thanx.
Old Jan 10, 2005 | 09:12 AM
mr.beeks's Avatar
Default Re: is sleeving the block bad for your pistons? (myDC4rox)
sleeving the block means you are getting a
bigger bore cylinder walls so you could acomodate biger pistons
therefore increasing your cc's
and gaining more torque on the low/med range.
so it doesnt mean that your pistons will wear out faster...
Old Jan 10, 2005 | 09:50 AM
Finger Lickin' good's Avatar
sleeving give the opportunity for stronger cylinder walls. I would only suggest in applications recieving over 1 bar of boost. It isnt cheap, and workmanship could be questionable.
Old Jan 17, 2005 | 10:35 PM
ExospeedAMcrx's Avatar
Block Sleeving is the process of cutting out part of the original cylinder sleeves and installing a thicker Iron Ductile Sleeve.
It will actually hold more pressure than stock sleeves during high boost applications.
Another thing sleeves let you do is do a bigger bore on the block. Lets say a regular B18C1 block is a 81mm bore, you can sleeve it and bore out to an 84mm bore. That results in about 2.0L
Almost a .2L increase in displacement which results in more torque and potential power for the motor.
There's more to this process but thats a brief explanation of it.
lsvtecturbosol
May 23, 2009 02:07 PM
kazino42
Jan 7, 2009 07:58 AM
lasthope05
May 19, 2006 09:03 AM
fastcivicboy
Mar 21, 2005 08:51 AM
Cyber ITR
Apr 24, 2002 06:41 PM
