idle problem with my 96 EK
Old Jan 10, 2005 | 08:10 AM
gtgoku's Avatar
Default idle problem with my 96 EK
well, I have notice that since saturday night when I got home from spinning the car is been idling relly low... to the point that most of the time it shuts off. so I was wondering how can I adjust the idling on the car? does anyone know?
thanks
Old Jan 10, 2005 | 08:15 AM
bbarbulo's Avatar
idle adjusts itself, so you should not adjust anything, else you'll just be covering up underlying problems. start with a good tune-up (plugs, wires, dizzy cap and rotor, air filter). 95% of the time, when there is no CEL, this is the problem. You can also check the IACV by Helm's instructions.
Old Jan 10, 2005 | 08:16 AM
NathanMorris's Avatar
Default Re: (bbarbulo)
you may also try the idle adjustment screw on the throttle body - however, as said above, make sure you rule out other issues first...
- Nathan
Old Jan 10, 2005 | 08:35 AM
gtgoku's Avatar
Default Re: (92Lx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Lx &raquo;</TD></TR><TR><TD CLASS="quote">you may also try the idle adjustment screw on the throttle body - however, as said above, make sure you rule out other issues first...
- Nathan</TD></TR></TABLE>
where is the screw located at? well it doesnt really matter as Im in the process of doing a k20 swap.
Old Jan 10, 2005 | 08:45 AM
Filthy Focker!'s Avatar
Default Re: (gtgoku)
Don't go play with your idle... Idle is not something that changes all of a sudden.
If you can't diagnos that symptom on an engine, that indicates that you do not have the knowledge to play with your idle.
Explain your problem a bit better. How did this first start? Did you do any mods to it prior? etc...
fs
Old Jan 10, 2005 | 08:52 AM
gtgoku's Avatar
Default Re: (filthy_shovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">
fs</TD></TR></TABLE>
but I can use that as a temporal fix right? until I have time to check.
Old Jan 10, 2005 | 08:55 AM
mp5o's Avatar
Old Jan 10, 2005 | 09:03 AM
gtgoku's Avatar
Default Re: (mp5o)
would I take that as a yes or no?
Old Jan 10, 2005 | 06:01 PM
gtgoku's Avatar
now the stupid things idles fine when I turn the car on... but as I drive it goes down to like 100 rpms =/
Old Jan 10, 2005 | 06:04 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtgoku &raquo;</TD></TR><TR><TD CLASS="quote">now the stupid things idles fine when I turn the car on... but as I drive it goes down to like 100 rpms =/</TD></TR></TABLE>
Check all of the basic things on your car. I.E. air filter, pcv valve, plugs, wires, cap, rotor, and check your EGR vlave as well.
Old Jan 10, 2005 | 06:33 PM
CivicEM's Avatar
Default Re: idle problem with my 96 EK (gtgoku)
That happened to my friends 97 civic with a GSR swap, and the shop replaced the idle air control and fixed the problem. Maybe check into it.
Old Jan 11, 2005 | 04:21 PM
gtgoku's Avatar
Default Re: idle problem with my 96 EK (CivicEM)
i would look into it.
Old Jan 12, 2005 | 07:39 AM
gtgoku's Avatar
Default Re: (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
Check all of the basic things on your car. I.E. air filter, pcv valve, plugs, wires, cap, rotor, and check your EGR vlave as well.</TD></TR></TABLE>
I checkk all of the above and nothing....
Old Jan 12, 2005 | 07:40 AM
gtgoku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEM &raquo;</TD></TR><TR><TD CLASS="quote">That happened to my friends 97 civic with a GSR swap, and the shop replaced the idle air control and fixed the problem. Maybe check into it.</TD></TR></TABLE> now. to check this... idle air control? where the hell is it? or what is it?
Old Jan 12, 2005 | 07:43 AM
Jon D's Avatar
where is the screw located at? well it doesnt really matter as Im in the process of doing a k20 swap.</TD></TR></TABLE>
then who gives a **** about the motor in the caR now...
Old Jan 12, 2005 | 11:43 AM
gtgoku's Avatar
Default Re: (B18C-Rsi)
me... as I need the car to move to go to work.
Old Jan 12, 2005 | 11:49 AM
PLAN:B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtgoku &raquo;</TD></TR><TR><TD CLASS="quote"> now. to check this... idle air control? where the hell is it? or what is it? </TD></TR></TABLE>
IACV is around the back of the intake manifold and throttle body. I believe you would be throwing a code 14 if that was the prob though.
Old Jan 13, 2005 | 05:53 PM
gtgoku's Avatar
Default Re: (PLANBmotorsports)
yeah Im not throwing any code... this is starting to be so anoying...
Old Jan 31, 2005 | 08:24 AM
gtgoku's Avatar
well, I change most of the stuff... spark plug cables, spark plugs, fuel filter, air filter. and nothing has change. what esle do yout think it can be... thats thing is driving me crazy =/
Old Jan 31, 2005 | 09:07 AM
d15z6's Avatar
Do you hawe Autodata 2004? I instaled it on my PC and it contains all data on how to set up idle and other stuf.
Old Jan 31, 2005 | 02:20 PM
gtgoku's Avatar
Default Re: idle problem with my 96 EK (d15z6)
nop, can you hook me up with it? what do I need?
Old Feb 1, 2005 | 04:16 PM
gtgoku's Avatar
could the alternator be bad?
vrrodri
Sep 19, 2007 08:04 AM
lude98SH
Mar 16, 2006 12:56 PM
jdmCivic925
Oct 25, 2005 02:37 PM
Slammed Ek9
Apr 7, 2005 03:00 PM
Ideal
Aug 22, 2002 08:51 PM
