HELP!!!!! mandrel bent pipes from kteller.com what sizes to get
From: home of Marciano/Haggler, city of champions, MA
im just a little confused at what sizes to get for my intercooler pipes. they make 45-90-180 degree bends. i have a 94 accord 94 h22. i only need the measurements from turbo to intercooler side, not intercooler to throttle body. thanks. it must clear power steering, ac, and stock radiator. thanks for your help.
If you have the ability to weld mild steel (with any crappy 110v flux-core MIG), just do what I do and buy 180° bends. You can cut the bends into whatever angles you need for the pipes. Often more than 1 radii of bend is available, in which case I buy the smallest radius for charge pipes and downpipes, and the larger radius for building an exhaust, since you generally have a lot more manuevering room under the car.
noluckracing
Welding / Fabrication
Jul 25, 2010 09:12 AM
