IS CHANGING A DISTRIBUTER ON A 2.2 VTEC 94 PRELUDE HARD?
Three bolts to remove distributor. Not hard. Honda distributors are keyed to only go in one way. Buy a timing light, there's instructions in the packaging, and search this board. Lots of threads concerning timing. preludes are 15 degrees of advance +/- 2 degrees.
pay attion to the way the teeth come out. there is a grove on the cam it goes into and will only fit 1 way.
yes you have to set timing. its easy if no one explains i will when i get home from work.
side note whats your setup? na? tc/sc?
infamousALLMTR
Nov 3, 2001 08:27 AM
