another stupid question by me..oem or what
ok now i found my ground wire from my valve cover all corrded and crappy and was wondering if i want to replace it, do i have to get an oem from handa dealer or just get the same thickness wire from a hardware store and replace it...
sorry for the stupid question just want to do things right.
thanks in advance
thanks in advance
lol @ grounding wires giving you horsepower.
If its just a little wire for grounding, get some similar gauge wire and some connectors and crimp and install.
this is true a grounding kit will give you hp but 98typesh was saying it dosent take much to do it yourself...get some speaker wire of a heavy gauge or any wire, you can replace it easily and if you want "more power" switch all your grounds with that wire.
i dont care about power now... all i want is to fix this ground wire because it casue my gadge to read that the cars going hot when the lights are turned on .
but thanks anyway
but thanks anyway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_behavior »</TD></TR><TR><TD CLASS="quote">Read up on it, i've read in SCC of a suzuki gaining 5whp.</TD></TR></TABLE>
yeah i'll believe stories in the national enquirer about Elvis being alive and a gay lover of tupac's before i believe a "technical" article in SCC...
ok ive called my nearest honda dealership and they said they dont supply it and that i should just check with a mechanic and replace it . so what do u recon guys should i just go to a normal car shop and get one from there...
maybe on cars with shitty wiring...like Suzukis...
just get a similar gauge wire...it's just wire.
i know a guy that "clamed" to gain 5 whp (clamed he dyno tested) on a 99 gs-t eclipse by changing to a thicker ground. but he would never show the dyno sheet..hmm wonder why?
gaining power is bulshit its prob was weaker from all the electrical problems from the ground. BUT
ANYWAY that frikkkennnnn *****8 8******* wire was the fault ive been look how to fix my so called over heating problem for 6 months and all it was was a WIRE....
one friken **8 ***** **** wire lol :@
But could't do it with out this site cheers boys.....
sickest and best tech site i know..
