bearing or spindle problem??
upon installing front integra knuckle, i noticed that (w/out axel, no motor in yet) the rotor seems to wobble. in this case, would just need to change the bearing or would i need a new knuckle assembly?
is the rotor wobbling or the hub? if the hub is wobbing inside of the bearing then you would have an issue. if the rotor is slid over the studs and the assembly line screws are not in of course it will wobble until you put the wheel on...
the rotors are screwed on tight. the hub and rotors wobble. im thinking i need new bearings. while a freind says i need a whole new hub and spindle. what do you guys think??
Nisif
Sep 23, 2006 06:59 PM
