Fan isn't working?
Old Jan 9, 2005 | 10:52 PM
yoohoo's Avatar
Default Fan isn't working?
Ok, so it was raining pretty hard today in socal. I drove through a big puddle and all of a sudden my heater stopped working. I tried turning the fan from high to low but nothing happens. The climate light indicator? (the light that tells you what button is pressed) also goes dead. Do you guys think I blew a fuse somewhere or did the puddle short something out? Help!
Old Jan 9, 2005 | 11:37 PM
yoohoo's Avatar
Default Re: Fan isn't working? (magicalfruit)
also the a/c stopped working also
Old Jan 9, 2005 | 11:42 PM
Calvinator's Avatar
Maybe one of your wires shorted out and blew a fuse, go check your fuse boxes.
skip.two's Avatar
check the fuses first. if that doesn't work, then you should ask questions.
Old Jan 9, 2005 | 11:55 PM
SirRevvs's Avatar
Default Re: Fan isn't working? (jL iLLuZiOnz 9)
Any time you lose power to anything in your car the first place you should check is the fuse box unless its a light bulb. It seems as if you already suspect a fuse to be blown anyhow.
Old Jan 10, 2005 | 03:31 PM
Yumm Tum Yummm's Avatar
yup first thing check your fan fuses under the hood and problably under the dash then check if theres any loose wires connecting to the fan.
Old Jan 10, 2005 | 07:24 PM
yoohoo's Avatar
Default Re: Fan isn't working? (EJ_FaNaTiK_22)
hey thanks for the replies. turns out the fuse was blown along with others! replaced them and the car was back to normal.
demiseraph
Aug 5, 2011 05:12 PM
hatchyksp
Aug 28, 2010 09:25 AM
Lil_Wyte
Jun 7, 2010 07:35 PM
Justinleexxx
Feb 18, 2010 12:43 PM
immajackuup
13
May 10, 2008 07:34 AM
