Not sure if engine is sitting right
b16a2 swap into eg, not sure if the guy that did the motor mounts (i gave him the picture that everyone on here uses, using th 3g teg mounts) messed them up and i don't know how to check. The shifter seems like its angling forward too much, in gears 1 3 5 and when its in 2 4 or R it lookes like its straight up, also the stock hood closes, but is definatly rubbing against the motor a little. I asked him about it and he said that the rear mount he had troubles getting in, and i'm thinking this is a big problem. Anyone know whats wrong with it?
The rear mounting bracket is a common "pain in the ***" problem for people who are relatively new to swapping Honda's. Double check to make sure that the rear mounting bracket is bolted in correctly. This is the only possible problem I can think of.
GrimeyAssLos
11
Feb 27, 2012 09:56 AM
Bob_760
Sep 7, 2006 08:50 PM
crxhybrid1320
Apr 20, 2003 07:00 PM
