Tranny troubleshooting HELP needed
Old Jan 9, 2002 | 11:41 AM
BudMan's Avatar
Default Tranny troubleshooting HELP needed
Since my local Acura shop wants $592 labor only to replace the clutch/pp/etc, I have thought about doing it myself - here's the problem tho....I need to diagnose whether they were full of **** in saying it needs new clutch assembly:
Symptoms (78,000 miles track & daily driver '98 Type R):
1) NEVER any slippage
2) 2 days ago during throttle blip/downshift to 3rd from 5th, it wouldn't go into gear for split second, then tried again & it went in fine, to 4th, then 5th & when I got off hwy - it worked fine!
3) yesterday, pulled in parking lot & couldn't get it into ANY gear! finally slammed into reverse 'cause I was blocking pkg traffic in front of building
4) After towing to Acura, they started it & it drove into the garage just fine.
5) When I left - car wouldn't even disengage from first with pedal down in Acura pkglot & car died. Started back up & it worked to drive 3 miles & get it in a gated/underground secured garage.
To me, this sounds more like hydrolic problems than the clutch itself, but that's jmho...
I wouldn't ask for extra help except Monday was my last day at work after layoff & I really don't want to replace lots of expensive parts if its the slave cylinder or other external hydrolic prob. Any help is appreciated before I tear into this beast!!!
Thanks,
Unemployed BudMan
[Modified by BudMan, 2:50 PM 1/9/2002]
Old Jan 9, 2002 | 01:28 PM
Solo2Vtec's Avatar
Default Re: Tranny troubleshooting HELP needed (BudMan)
Have you tried bleeding the fluid?
Old Jan 9, 2002 | 02:30 PM
BudMan's Avatar
Default Re: Tranny troubleshooting HELP needed (LSVtec2000)
Actually, I bought fluid to do this last week - lol...I have to go get my car tonight/tomorrow from the secured parking area & I was thinking of flushing the fluid while still in the parking lot - if Batoutahell will go with me ;-)
I'm hoping that's causing the slave cylinder to not pull the release fork everytime...
Is that what you were thinking???
All opinions appreciated!
BudMan I need
Old Jan 9, 2002 | 03:54 PM
sgT's Avatar
sgT
It could be the release bearing going out or the pressure plate has a problem.
Or the disc is coming apart and is getting stuck and making the clutch not release.
It could very well be, but i wouldnt let those dealer monkeys do the work
Old Jan 9, 2002 | 04:18 PM
BudMan's Avatar
Default Re: Tranny troubleshooting HELP needed (sgT)
I appreciate your response....at least you've given me several possibilities that WOULD require clutch/pp/bearing replacement!!
Thanks - I'll start working tomorrow
Any other thoughts are still appreciated!!
Old Jan 9, 2002 | 06:14 PM
BudMan's Avatar
ttt
Any other ideas??
Have a free on me!
Old Jan 9, 2002 | 06:20 PM
ZygSpeed's Avatar
One last minute check.
If it "pumps up" then it might just be the "hydraulics" (no pun intended),
otherwise it looks like your disc/disk failed (popped a spring or any of those other possible problems).
Any "special" abuse you've given it lately?
Old Jan 9, 2002 | 06:21 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Jeff: Any abnormal noises?
Old Jan 10, 2002 | 04:17 AM
BudMan's Avatar
Default Re: Tranny troubleshooting HELP needed (Dave-ROR)
No sirry "Mullet Man"...hehehe
Actually, I've been driving unusually kind lately -'cause I was going to flush the fluid & change the mtf {it's in the back seat - bought the day before it went out - lol}
I guess lightened flywheel & new clutch goodies are in order....I'll have to do a search for any tips on this process. Crappy part is I just put in the new motor mount inserts 2 weeks ago & now I apparently have to pull them back out to get the tranny out - lol.
Thanks for the help!
BudMan - who surely will abuse his car even more after this!!
Old Jan 10, 2002 | 06:41 PM
BudMan's Avatar
Upon checking today I noticed the boot over the "Release Fork" has a tear in it. Should I be able to move the fork by hand (push the slave cylinder push rod back into the cylinder)??
I'm thinking that I might have a bad slave cylinder - thoughts anyone?? before I tear into the tranny?
Old Jan 15, 2002 | 03:57 PM
Striker's Avatar
New User
Probably pressure plate
Old Jan 15, 2002 | 03:59 PM
sgT's Avatar
sgT
yes you can push the rod into the cylinder by hand.
Old Jan 15, 2002 | 05:49 PM
BudMan's Avatar
All is installed & all is running nicely Thanks to all who helped the tranny-newbie!!
Old Jan 15, 2002 | 06:11 PM
b00st-0wnz's Avatar
gsr_b20b
Jul 17, 2009 03:53 AM
Tiauna
Honda Civic (2001 - 2005)
12
Dec 23, 2008 02:32 PM
SlammedBlackGSR
Sep 3, 2007 06:36 PM
redLUDEs2k1
Sep 8, 2005 05:20 PM
ar5enal
Apr 27, 2003 06:44 PM
