My car Dies or Bogs out when I go on the gas !! Help
when i started my car yesterday, it warmed up fine. When I was leaving my house it started to bog a little when i pressed more on the gas. Then when i was at a stop sign and went to go and pressed on the gas the car started bogging a little then started goin. I shut it off and started it a minute later. it started and shut off. waited like 15 seconds and it started. I took it to my buddies house that live few blocks away. the problems continued and worsened. Now when id go on the gas fast it would die out completely or bogg really bad. even at higher rpm it would bog. then it backfired once or twice before it would shut off. the idle was pretty normal though. it was only when I would go on the gas for the most part. Im not sure whats wrong i have a few things im thinking could be it but not sure what. if anyone had these problems and fixed it and could help me out id really appreciate it.
Could be the main relay, or the fuel pump/filter(stupid me ran the car outa gas it may have clogged, car never has alot of gas in it half tank at most. only super premium gas is used. , could it be the ecu? or the timing? but i think if it were the timing that it wouldnt idle good either.
Also, even when i had my stok dx motor in my car when i would start my car it would start for a second and turn off, then take about 15 seconds or so and try to start it agian and it start. does the same thing on my jdm b16 not sure why. any help would be great. thanks
YEAH I HAVE THAT BOGGIN' PROBLEM TOO .. when I STEP ON GASSS IT LAG OR BOGG but when I step on it SLOWLY it will gooo.. but still runnn shtty .. sometime it die out itself. I AM WONDERIN whats wrong with it also.
I had a similar problem. check your fuel pressure. then if its fine, check the distributor. the distributor ended up being my problem.
I think its the fuel pump or something though, ever since it ran outa gas like 2 weeks ago hasnt run right all the time. seemed to hesitate or bog when dirving and i floor it, then it would pick up outa nowhere. starts and dies sometimes and now when idling and go on the gas it acts up. Im about to say f*ck this and get my s2k
i had the smae problem too when i did a mini me. i plug the wrong plug for the tps sensor and the map sensor. the plug were crossed.
i have the same problem.. except my car doesnt completely bog down. I took it to a friends shop and he said it was a tps sensor. Going to cost me about $160 for a brand new sensor... if its not that I'm guessing its the fuel pump.
i thought mine was the fuel pump..but from what i hear honda fuel pumps are pretty damn good..so im not leaning in that direction, just my thought though..do what you want...also check your engine code anyway..the ecu stores them in there
’92 Eg6 Jdm Hatchback
Milano red, 80k miles on chassis, 45k motor,28k tranny
Engine:
Jdm b16 -- 46xxx miles
’01 type R transmission –28xxx miles
exedy stage 2 clutch
intake
Jun flywheel
Itr intake manifold
Euro type R throttle body
Gsr cams
Skunk2 cam gears
Greddy 4-2-1 header
Test pipe
RSR ex-mag catback
Shifter bushings
Itr linkage
Dc sports short shifter
Socketed hondata ready p72 ecu (currently running custom setup made from kenji)
Itr valve cover
Msd wires
Interior:
Momo steering wheel
Jdm type R cluster
Spoon shift ****
Del sol seats *mint* black w/gray stripe
Jdm optional console
Sparco 3pt harness
Stripped rear interior
Pioneer amber cd player and door speakers
Rear speaker brackets and hook-up
Exterior:
Brand new stock ex/si front lip
Brand new wings west rear lip
’00 Si rims with 2 dunlop fm901, 2 yokahama avid
Stock headlights black housing
Amber corners tinted
Hid’s out of ’04 maxima
All red taillights
Suspension:
vis coilovers
Kyb gr2 shocks
Front strut bar
Rear upper strut bar
Dc sports lower rear bar
B-pillar bar
Security:
Prestige car alarm/remote start
Door lock actuators
Things going on in spring !!!!
T3 super 60 turbo < 1000miles rebuild
Lovefab shorty manifold
Dsm 450cc injectors
Hondata stage 2 with boost
Johnny race car 8” fmic
Hks ssq bov
Custom intercooler piping
Custom downpipe and dumptube
Tial 38mm wastegate
Gsr tapped oil pan
Greddy turbo timer
Autometer boost,air/fuel, oil pressure gauges
Greddy egt gauge
Manual boost controller
Engine:
intake
Jun flywheel
Itr intake manifold
Gsr cams
Skunk2 cam gears
Greddy 4-2-1 header
Test pipe
RSR ex-mag catback
Shifter bushings
Itr linkage
Itr valve cover
Msd wires
Interior:
Momo steering wheel
Jdm type R cluster
Spoon shift ****
Sparco 3pt harness
Exterior:
All red taillights
Suspension:
vis coilovers
Kyb gr2 shocks
Front strut bar
B-pillar bar
Security:
Door lock actuators
Dsm 450cc injectors
Hks ssq bov
Tial 38mm wastegate
Gsr tapped oil pan
Greddy turbo timer
Greddy egt gauge
Wilky
11
Feb 18, 2007 09:58 PM
