Gaskets for b20 ?
i have a b20 motor with a gsr head and its getting built right now so which gaskets do i need? Can i use all the gaskets for a gsr or do i need all the gaskets for a crv and if so what year, or do i need some from the gsr and others from the crv and if so which ones? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">which gaskets do u need to replace?
if its for the block, get the gasket for the CRV, but for the head, use gaskets for a GSR</TD></TR></TABLE>
and there you are...
just make sure your water pump and timing belt match (are for the same motor, whichever one you pick)
-Mike
just make sure your water pump and timing belt match (are for the same motor, whichever one you pick)-Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord »</TD></TR><TR><TD CLASS="quote">as for head gasket i ran a cometic 84mm with a block guard
as did I... we'll see how both hold up with a turbo...
to be continued...
-Mike
</TD></TR></TABLE>as did I... we'll see how both hold up with a turbo...
to be continued...
-Mike
CW-ITR
10
Oct 5, 2007 11:43 AM
