Coarse thread or Fine thread?
Old Jan 9, 2005 | 04:44 PM
B18EG6's Avatar
Default Coarse thread or Fine thread?
just curious-
from an engineering standpoint... Which has better holding power, fine thread (NF) or corase thread (NC) ? What pro's and cons do both have?
Thanks in advance
Old Jan 11, 2005 | 06:08 AM
B18EG6's Avatar
Default Re: Coarse thread or Fine thread? (B18EG6)
guess theres no specific answer.
fine thread it is!
Old Jan 11, 2005 | 07:20 AM
snatch's Avatar
Interesting...there are two ways I can think of to look at it.
1) Fine threads are weaker because, since there are more threads there are more stress concentrations, therefore rendering it weaker. However, there is probably a fillet between the side of the thread and the bolt. A thread isn't completely squared, rather takes on more of a teepee shape (for lack of a better way to describe it).
2) Fine threads are stronger because, even though there are more threads and the possibility of more stress concentrations, if these stress concentrations are not very prevalent, then there are more threads to take the load applied to the bolt.
All in all, I remember 100% that you do not want shear force applied to a bolt. Tension is the best type of stress a bolt can see because that's what they're designed for.
Hopefully that makes some sense. Doubtfully though
Old Jan 11, 2005 | 07:35 AM
spoonek9's Avatar
There is no specific answer because there is not enough information. Determining which thread series to use depends on a bunch of things like, what material is being used, length of engagement , wall thickness, design of the part........ there are a lot of things to consider.
Old Jan 11, 2005 | 03:35 PM
BigMoose's Avatar
Default Re: Coarse thread or Fine thread? (spoonek9)
There are a "lot of things" to consider, but I will share my rules of thumb.
Fine thread bolts of the same size, typically have a larger thread root diameter. Hence they have a larger minimum cross section, and are stronger.... if you have a nice material to thread them into, like steel. If you are going into aluminum, I choose coarse thread, due to the fragility of small aluminum threads, and their propensity to gall and strip out. I use coarse thread in cast iron due to grain size effects.
Coarse thread will distribute the stress better into a threaded aluminum plate, fine thread will try to load all the stress into the first 2 or 3 threads, the neck down of the coarse thread will give a little and put the stress into the first 3 or 4 threads... that little change can add a lot of life to the joint.
Run some finite element analyses of a bolted joint and you will see what I am talking about.
Old Jan 11, 2005 | 08:26 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: Coarse thread or Fine thread? (BigMoose)
with us.. i keep sucking the threads right out of the block with my tranny bolts... so grade 8 bolts are stronger than cast aluminum... is that what you were asking? hehe
Old Jan 12, 2005 | 04:37 AM
snatch's Avatar
Default Re: Coarse thread or Fine thread? (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">
Run some finite element analyses of a bolted joint and you will see what I am talking about.</TD></TR></TABLE>
Good call on this one. Run some FEA if you have access to a program and see what you come up with. You can vary between coarse and fine thread, and vary the load too if desired.
Old Jan 12, 2005 | 08:15 AM
B18EG6's Avatar
Default Re: Coarse thread or Fine thread? (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">
Good call on this one. Run some FEA if you have access to a program and see what you come up with. You can vary between coarse and fine thread, and vary the load too if desired.</TD></TR></TABLE>
I dont have access to such programs wish I did though!
Most of the load is axial, with very minimal transverse load applied. The material is aluminum.
I appreciate all this input - it makes me want to go bug my university to get some new better engineering teachers.... dont get me started with the engineering program we have
Thanks for all of your replies!
shortyz
Jul 1, 2005 12:30 PM
al3e
Dec 14, 2003 04:07 PM
civicgsr91
Oct 9, 2002 09:58 PM
