brake lights on 90 accord stay on all the time
Old Jan 9, 2005 | 04:07 PM
jeff_br26's Avatar
Default brake lights on 90 accord stay on all the time
My Accord EX has the brake lights on all of the time. I have factory installed tail fin with LED lights as well. Up until yesterday as soon as it touched brake pedal the sensor in console would show the brake lights as having a problem.
This is what i have done thus far to eliminate the problem:
- Disconnected tail fine led lights
- Unplugged tail lights one at a time in case of short
- Disconnected 3 amp fuse on right rear light
Is there some kind of sensor by the fuse box or under the dash. If so where might it be.
I think if i can locate that then i may have solved the problem. Does anyone have any wiring diagrams as well?
Thanks for any advice on this since I have been rackin my brain trying to figure it out.
Old Jan 10, 2005 | 06:35 AM
JimBlake's Avatar
Default Re: brake lights on 90 accord stay on all the time (jeff_br26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeff_br26 &raquo;</TD></TR><TR><TD CLASS="quote">Is there some kind of sensor by the fuse box or under the dash. If so where might it be.</TD></TR></TABLE>How about the switch on the brake pedal?? Maybe it's as simple as a bent bracket so it doesn't turn off when your foot is off the brakes.
Old Jan 10, 2005 | 07:36 AM
Suke's Avatar
can you tell me where that 3 amp fuse on the rear right light is located?
it would help me fix my own problem.
Old Jan 10, 2005 | 07:40 AM
Superman137's Avatar
Default Re: brake lights on 90 accord stay on all the time (Suke)
my 92 accord does the same thing and never have figured out y it does that it's still on till this day?
90AccordTx
Apr 17, 2006 11:14 AM
citrus3000psi
Oct 13, 2005 12:27 PM
Jahtoot84
Aug 15, 2005 07:59 PM
FullMetalJacket
12
Apr 29, 2003 10:07 AM
EGh22aEG
Aug 25, 2002 01:28 PM
