Suggestions on what engine to swap into my 91 HB STD civic
Old Jan 9, 2005 | 03:42 PM
Playa_FL's Avatar
Default Suggestions on what engine to swap into my 91 HB STD civic
STD is standard right? I want to swap in the B16A motor. Can i swap in a different motor that will create more hp w/o alot of modifications? What head can i use? What cams? I want to get about or around 200 hp out of this motor. Any guys with the ultimate set-up please share info thanks! Oh yea, i want this to be a daily driver also.
Old Jan 9, 2005 | 04:02 PM
Gant's Avatar
first swap u should at all first is mpfi then continue on
Old Jan 9, 2005 | 04:49 PM
Playa_FL's Avatar
Default Re: (Ba4)
I should first do a MPFI and not a swap?
Old Jan 9, 2005 | 05:53 PM
limpy's Avatar
Default Re: (Playa_FL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Playa_FL &raquo;</TD></TR><TR><TD CLASS="quote">I should first do a MPFI and not a swap?</TD></TR></TABLE>
you must do the mpfi before you can do a swap.
Old Jan 9, 2005 | 06:01 PM
Playa_FL's Avatar
Default Re: (limpy)
Why??
Old Jan 9, 2005 | 06:08 PM
Gant's Avatar
lol wow u really need to do more search
the reason why is cause u have dual point fuel injection. if u want to do a swap u have to switch over to mutli port fuel inejction, u only have 2 INJECTORS.
Old Jan 12, 2005 | 08:21 AM
Playa_FL's Avatar
Default Re: (Ba4)
Cant I just get an SI wiring harness for the B16?
Old Jan 12, 2005 | 08:52 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Playa_FL &raquo;</TD></TR><TR><TD CLASS="quote">Cant I just get an SI wiring harness for the B16?</TD></TR></TABLE>
You could, but it won't work.
The engine harness plugs into another harness at large connectors located under the hood at the firewall. This harness runs into the car and hooks up to the ECU.
You can completly remove the engine from the car with the engine harness still on it - unlike some domestics I've seen.
Anyway, the wiring on the DPFI engine harness is different than the MPFI harness so when you plug it into the ECU harness it doesn't work.
The best/easiest way to do the MPFI conversion is to just modify your existing harness. It's really not hard at all so don't be discouraged.
Old Jan 12, 2005 | 01:28 PM
Playa_FL's Avatar
Default Re: (4drEF)
when i order my new B16 will it come with the wiring harness that i need? and if so, all i have to do is modify the connector at the firewall on my car?
Old Jan 12, 2005 | 02:46 PM
halvoric's Avatar
If your B16 comes with the B16 engine wiring harness, you will want it, but mostly to take some connectors from it. You then splice those connectors onto your DX harness. You'll also need to move some wires at the ECU plugs and add some new wire runs (4 wires I think--2 for additional injectors, 2 for the Cylinder Position Sensor) from the ECU plugs through the firewall and into the engine bay. You also lengthen a couple of sensor leads (like TPS) and reverse the wiring of the TPS connector. If you go B16, you'll also want to wire up some kind of VTEC controller.
This site gets linked a lot for straight DPFI-MPFI swap:
http://www.fourthgenhatch.com/mpfi.html
Old Jan 12, 2005 | 02:52 PM
Recluse03's Avatar
search + google. ****
Old Jan 12, 2005 | 02:56 PM
Nay's Avatar
Nay
Default Re: Suggestions on what engine to swap into my 91 HB STD civic (Playa_FL)
Doing it yourself is cool and all, but paying a shop the little extra is more than worth the money. No hassle. Install a B16 and all the easy bolt ons and you will make around 150whp. Thats a good starting point.
Old Jan 12, 2005 | 03:01 PM
kaoss_11's Avatar
B A N N E D
whatever your money can afford.
Old Jan 12, 2005 | 03:03 PM
CRX Toad's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">lol wow u really need to do more search
the reason why is cause u have dual point fuel injection. if u want to do a swap u have to switch over to mutli port fuel inejction, u only have 2 INJECTORS.</TD></TR></TABLE> SEARCH IS GOD THis has only been cover since the day your car came out
I search and found this https://honda-tech.com/zerothread?id=1016251
Honda-Tech.com » CRX / EF Civic » **The Official "What's the best engine for my Honda" thread...the Answers inside*** [Archived]
Old Jan 13, 2005 | 05:23 AM
Playa_FL's Avatar
Default Re: (halvoric)
What is a V-tech controller?
Old Jan 13, 2005 | 06:08 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Playa_FL &raquo;</TD></TR><TR><TD CLASS="quote">STD is standard right? I want to swap in the B16A motor. Can i swap in a different motor that will create more hp w/o alot of modifications? What head can i use? What cams? I want to get about or around 200 hp out of this motor. Any guys with the ultimate set-up please share info thanks! Oh yea, i want this to be a daily driver also.</TD></TR></TABLE>
Drop a B18c5 in that car. It will be a little bit more wiring, depending on how you do it, and then you will have to get the hydro conversion mounts. Then you are at 200 with a stock engine. You should do a search for red civic standard, he is running this same setup, with some other mods also. As others mentioned though searching is your friend.
Old Jan 13, 2005 | 10:48 AM
Playa_FL's Avatar
Default Re: Suggestions on what engine to swap into my 91 HB STD civic (CRXBart)
oh damn i didn't know that a B18C5 would fit. I read that it would take alot more extensive work to make it fit since motor mounts arent made to directly swap it in. Or is this true? Will it drop right in with the aftermarket motor mounts?
Old Jan 13, 2005 | 11:46 AM
fastassdx's Avatar
From: Come back next year and Ill put some, eggnog in your face, US
Hey I did the same swap in my 88 dx, it was not that hard. If you want any help just ask.
Old Jan 13, 2005 | 12:04 PM
mrdanglez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Playa_FL &raquo;</TD></TR><TR><TD CLASS="quote">oh damn i didn't know that a B18C5 would fit. I read that it would take alot more extensive work to make it fit since motor mounts arent made to directly swap it in. Or is this true? Will it drop right in with the aftermarket motor mounts?</TD></TR></TABLE> search! nah from what i heard should fit .....bro search
Old Jan 13, 2005 | 12:35 PM
Playa_FL's Avatar
Default Re: Suggestions on what engine to swap into my 91 HB STD civic (mrdanglez)
When you guys say search, when do you mean by that? just surf the web and stuff for more info? ODB1 and ODBII what does those terms mean and what are they?
Old Jan 13, 2005 | 12:37 PM
EP3_05's Avatar
In the upper right hand corner there is a button that says serach. You can use it to search all of the content on honda-tech.
Old Jan 13, 2005 | 01:54 PM
91hatch_on17's's Avatar
Default Re: Suggestions on what engine to swap into my 91 HB STD civic (91civic)
sounds to me like someone is trying to **** of people...lol..but yeah...search!!!!!
Old Jan 13, 2005 | 02:09 PM
biggdogg's Avatar
Default Re: Suggestions on what engine to swap into my 91 HB STD civic (91hatch_on17's)
OSMOSIS IS YOUR FRIEND. just take your computer and set it on your head . then you will know everything.
Old Jan 13, 2005 | 03:49 PM
Playa_FL's Avatar
Default Re: Suggestions on what engine to swap into my 91 HB STD civic (biggdogg)
What???
Old Jan 13, 2005 | 04:00 PM
gtarwiz's Avatar
just use the search button! it is GOD! the no all and see all button of Honda-tech! it's my best friend!
